Introducción
Have you lost or broken a wheel spoke? This guide will show you how to replace it.
Using the 4mm Allen wrench, partially unscrew the 4 (22mm) hex screws on the front of the axle casing to allow the axle to slide freely.
  • Using the 4mm Allen wrench, partially unscrew the 4 (22mm) hex screws on the front of the axle casing to allow the axle to slide freely.
Agregar Comentario
Using the 8mm Allen wrench, loosen the axle screw until 1/2 of the axle screw is visible. Push the axle screw to reveal the axle rod on the other side.
  • Using the 8mm Allen wrench, loosen the axle screw until 1/2 of the axle screw is visible.
  • Push the axle screw to reveal the axle rod on the other side.
Agregar Comentario
Using the Allen wrench, finish unscrewing the axle screw and pull it out.
  • Using the Allen wrench, finish unscrewing the axle screw and pull it out.
  • Hold the wheel when pulling out the axle rod so that the bike does not fall.
Agregar Comentario
Pull the wheel from the fork.
  • Pull the wheel from the fork.
Agregar Comentario
Twist and pull off the cap covering the tire valve Twist off the spacer that holds the valve in place. Push valve in toward wheel to release air pressure.
  • Twist and pull off the cap covering the tire valve
  • Twist off the spacer that holds the valve in place.
  • Push valve in toward wheel to release air pressure.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Insert one tire lever between the tire and the rim. Push down on the tire lever until the edge of the tire is higher than the edge of the rim. Insert a second tire lever next to  the first.
  • Insert one tire lever between the tire and the rim.
  • Push down on the tire lever until the edge of the tire is higher than the edge of the rim.
  • Insert a second tire lever next to the first.
  • Slowly slide one tire lever around the rim until the tire is released from the rim.
Agregar Comentario
Using your hand, pull the tube completely out of the tire.
  • Using your hand, pull the tube completely out of the tire.
Agregar Comentario
Use an 8mm Allen wrench to unscrew the 6 (4x10mm) screws on the brake rotor.
  • Use an 8mm Allen wrench to unscrew the 6 (4x10mm) screws on the brake rotor.
  • Pull brake rotors off both sides of the wheel.
Agregar Comentario
Pull the tire from the rim.
  • Pull the tire from the rim.
Agregar Comentario
Using a tire lever, push the rim tape aside to reveal the spoke nipple.
  • Using a tire lever, push the rim tape aside to reveal the spoke nipple.
  • Using your fingers, pull off the old spoke nipple.
Agregar Comentario
Push out the old spoke from the hub.
  • Push out the old spoke from the hub.
Agregar Comentario
Insert a new 250mm spoke into the hub. Align the spoke with the spoke nipple in the rim.
  • Insert a new 250mm spoke into the hub.
  • Align the spoke with the spoke nipple in the rim.
  • Try to keep the spoke as straight as possible when threading it around the other spokes. Slight bends will be taken out when it is tightened.
Agregar Comentario
Using an SW-1 spoke wrench, tighten the spoke.
  • Using an SW-1 spoke wrench, tighten the spoke.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Sterling Grande
Miembro Desde 08/10/12
126 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 9-14, Amido Fall 2012 Miembro de Cal Poly, Team 9-14, Amido Fall 2012
CPSU-AMIDO-F12S9G14
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 16
Todo El Tiempo: 1,377
