Introducción
Installing the rear shock.
Herramientas
Partes
No se requieren partes.
Orient the bike upside down.
  • Orient the bike upside down.
Agregar Comentario
Remove the 10mm screw and take the bash guard off of the frame.
  • Remove the 10mm screw and take the bash guard off of the frame.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove the 65mm screw that connects the bottom of the shock to the frame.
  • Remove the 65mm screw that connects the bottom of the shock to the frame.
  • As shown in the blue box, you will need to use a wrench to hold the other side.
Agregar Comentario
Remove the 40mm screw that connects the shock to the link arm of the suspension.
  • Remove the 40mm screw that connects the shock to the link arm of the suspension.
Agregar Comentario
Push the shock out of the brackets mounting it to the frame and suspension arm. This may require some force and slight wiggling from side to side.
  • Push the shock out of the brackets mounting it to the frame and suspension arm.
  • This may require some force and slight wiggling from side to side.
Agregar Comentario
Conclusión
Andrew Krasts
Miembro Desde 05/10/12
244 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 9-14, Amido Fall 2012 Miembro de Cal Poly, Team 9-14, Amido Fall 2012
CPSU-AMIDO-F12S9G14
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 14
Últimos 30 Días: 47
Todo El Tiempo: 2,924
