Introducción
Use this guide to replace the internal battery of the handset
Unplug the device before proceeding. Remove the phone cord from the phone jack from the base of the headset.
  • Unplug the device before proceeding.
  • Remove the phone cord from the phone jack from the base of the headset.
    • Use a plastic opening tool to remove the phone cord.
Agregar Comentario
Remove the phone cord screw cap. Unscrew the 7.5mm screw. Remove the screw cap.
  • Remove the phone cord screw cap.
    • Unscrew the 7.5mm screw.
    • Remove the screw cap.
  • Remove the cord from the phone base.
Agregar Comentario
Remove the plastic cover with a Plastic Opening Tool by gently sliding the tool underneath the plastic and pry the cover off. Remove the plastic cover with a Plastic Opening Tool by gently sliding the tool underneath the plastic and pry the cover off.
  • Remove the plastic cover with a Plastic Opening Tool by gently sliding the tool underneath the plastic and pry the cover off.
Agregar Comentario
Remove the paper with a Plastic Opening Tool by gently sliding the tool underneath and prying the paper away from the phone.
  • Remove the paper with a Plastic Opening Tool by gently sliding the tool underneath and prying the paper away from the phone.
Agregar Comentario
Remove the rubber stopper with a Plastic Opening Tool by gently sliding the tool underneath and pry away from the phone. Remove the rubber stopper with a Plastic Opening Tool by gently sliding the tool underneath and pry away from the phone.
  • Remove the rubber stopper with a Plastic Opening Tool by gently sliding the tool underneath and pry away from the phone.
Agregar Comentario
Remove the two screws. Remove the 2 21mm screws by using a Philips #1 screwdriver.
  • Remove the two screws.
    • Remove the 2 21mm screws by using a Philips #1 screwdriver.
Agregar Comentario
Pull apart the handset by pulling the shell away from the other half of the phone.
  • Pull apart the handset by pulling the shell away from the other half of the phone.
Agregar Comentario
Remove 3 screws attaching the logic board to shell. Remove the 13mm screw with a Philips #1 screwdriver.
  • Remove 3 screws attaching the logic board to shell.
    • Remove the 13mm screw with a Philips #1 screwdriver.
    • Remove the 2 13mm screws with washers with a Philips #1 screwdriver.
Agregar Comentario
Slide out the phone jack from the shell by gently lifting up the phone jack. Slide out the phone jack from the shell by gently lifting up the phone jack.
  • Slide out the phone jack from the shell by gently lifting up the phone jack.
Agregar Comentario
Without removing the logic board completely, pivot the logic board out of shell.
  • Without removing the logic board completely, pivot the logic board out of shell.
Agregar Comentario
Use tweezers to apply pressure on battery holder tabs.
  • Use tweezers to apply pressure on battery holder tabs.
  • Apply pressure directly on battery holder to slide it through the shell.
    • Battery is going to slide through the bottom.
Agregar Comentario
Lift tabs on the side of the holder by putting your fingers directly on the tab to pull it apart. While holding the battery, remove it from the holder.
  • Lift tabs on the side of the holder by putting your fingers directly on the tab to pull it apart.
  • While holding the battery, remove it from the holder.
Agregar Comentario
Now insert the new battery.
  • Now insert the new battery.
    • Ensure that the positive side of the battery is facing the tabs.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 16-59, Forte Fall 2012 Miembro de Cal Poly, Team 16-59, Forte Fall 2012
CPSU-FORTE-F12S16G59
4 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 4
Todo El Tiempo: 1,045
