Saltar al contenido principal
Gateway SA1 Outer Casing Replacement
Qué necesitas
  1. Gateway SA1 Outer Casing Replacement, Battery: paso 1, imagen 1 de 1
    • Move the latch to the right of the battery to unlock.
  2. Gateway SA1 Outer Casing Replacement: paso 2, imagen 1 de 1
    • Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
    • The latch must be held in position to remove the battery.
  3. Gateway SA1 Outer Casing Replacement, Disk Drive: paso 3, imagen 1 de 1
    • Unscrew the marked 5.9 mm Philips screw.
  4. Gateway SA1 Outer Casing Replacement: paso 4, imagen 1 de 1
    • Use the spudger to pry out the Disk dive.
  5. Gateway SA1 Outer Casing Replacement: paso 5, imagen 1 de 1
    • The disk drive should easily detach and can now be replaced.
  6. Gateway SA1 Outer Casing Replacement, Outer Casing: paso 6, imagen 1 de 1
    • Remove the twelve 5.9 mm Philips screws from the back cover.
    • Remove one 8.8 mm Philips screw from the back cover.
  7. Gateway SA1 Outer Casing Replacement: paso 7, imagen 1 de 3 Gateway SA1 Outer Casing Replacement: paso 7, imagen 2 de 3 Gateway SA1 Outer Casing Replacement: paso 7, imagen 3 de 3
    • Unscrew the two 5.9 mm Philips screws located on the the side closest to the battery.
    • Unscrew the three 3.6 mm Philips screws that are within the Disk drive port.
  8. Gateway SA1 Outer Casing Replacement: paso 8, imagen 1 de 2 Gateway SA1 Outer Casing Replacement: paso 8, imagen 2 de 2
    • Remove the hinge covers by lifting each with the sharp point of the spudger.
    • Notice that the middle cover has a different shape and is more difficult to remove.
  9. Gateway SA1 Outer Casing Replacement: paso 9, imagen 1 de 3 Gateway SA1 Outer Casing Replacement: paso 9, imagen 2 de 3 Gateway SA1 Outer Casing Replacement: paso 9, imagen 3 de 3
    • There will be a connection underneath the speaker cover.
    • Remove the speaker cover using the spudger.
  10. Gateway SA1 Outer Casing Replacement: paso 10, imagen 1 de 1
    • Unscrew the two 3.9 mm Philips screws and remove the keyboard.
  11. Gateway SA1 Outer Casing Replacement: paso 11, imagen 1 de 3 Gateway SA1 Outer Casing Replacement: paso 11, imagen 2 de 3 Gateway SA1 Outer Casing Replacement: paso 11, imagen 3 de 3
    • Carefully lift the keyboard off from the laptop. It is still attached as shown.
    • Using the spudger, detach the connector by pushing two tabs away from the white connector and then gently pulling the connector away.
    • The brown colored component with the tabs does not come out with the connector.
  12. Gateway SA1 Outer Casing Replacement: paso 12, imagen 1 de 3 Gateway SA1 Outer Casing Replacement: paso 12, imagen 2 de 3 Gateway SA1 Outer Casing Replacement: paso 12, imagen 3 de 3
    • Lift up the black tab and gently pull out the connector.
  13. Gateway SA1 Outer Casing Replacement: paso 13, imagen 1 de 2 Gateway SA1 Outer Casing Replacement: paso 13, imagen 2 de 2
    • Unscrew the four marked 5.9 mm Philips screws.
  14. Gateway SA1 Outer Casing Replacement: paso 14, imagen 1 de 2 Gateway SA1 Outer Casing Replacement: paso 14, imagen 2 de 2
    • Move the wires out of the fixed space as shown.
  15. Gateway SA1 Outer Casing Replacement: paso 15, imagen 1 de 2 Gateway SA1 Outer Casing Replacement: paso 15, imagen 2 de 2
    • Unscrew the five marked 3.8 mm Philips screws.
    • Three screws are located on the right side of the screen.
    • Two screws are located on the left side of the screen.
  16. Gateway SA1 Outer Casing Replacement: paso 16, imagen 1 de 1
    • Remove the screen brackets from the computer's base.
  17. Gateway SA1 Outer Casing Replacement: paso 17, imagen 1 de 3 Gateway SA1 Outer Casing Replacement: paso 17, imagen 2 de 3 Gateway SA1 Outer Casing Replacement: paso 17, imagen 3 de 3
    • Remove the four 5.9 mm Philips screws as indicated:
    • There is one somewhat hidden screw on the left side under the screen hinge, and one to the right of the (left)speaker, right/top side of the video port on mobo.
    • There are two similarly positioned screws on the right side.
  18. Gateway SA1 Outer Casing Replacement: paso 18, imagen 1 de 2 Gateway SA1 Outer Casing Replacement: paso 18, imagen 2 de 2
    • The following steps (18 - 20) explain how to remove the three indicated connections.
    • The order is Blue, Violet, Orange.
    • Lift the white tab up and gently take out the connector.
  19. Gateway SA1 Outer Casing Replacement: paso 19, imagen 1 de 1
    • Use the spudger to pull off the black attachment.
  20. Gateway SA1 Outer Casing Replacement: paso 20, imagen 1 de 1
    • Lift and pull the black tab upward until it becomes unattached.
    • Some force may be required.
  21. Gateway SA1 Outer Casing Replacement: paso 21, imagen 1 de 1
    • Use the spudger to remove the casing as seen in the picture.
  22. Gateway SA1 Outer Casing Replacement: paso 22, imagen 1 de 1
    • Remove the casing.
Conclusión
6 personas más completaron esta guía.
Equipo
Cal Poly, Team 24-20, Regan Spring 2010 Miembro de Cal Poly, Team 24-20, Regan Spring 2010
CPSU-REGAN-S10S24G20
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 15,953
