Saltar al contenido principal
Gateway SA1 Hard Drive Replacement
Qué necesitas
  1. Gateway SA1 Hard Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Move the latch to the right of the battery to unlock.
  2. Gateway SA1 Hard Drive Replacement: paso 2, imagen 1 de 1
    • Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
    • The latch must be held in position to remove the battery.
  3. Gateway SA1 Hard Drive Replacement, Hard Drive: paso 3, imagen 1 de 1
    • Before you begin, it's recommended that you back up all your computer's information on the original hard drive. Also, verify the laptop is off and all cables are disconnected.
    • Turn the laptop over so the bottom is facing up.
  4. Gateway SA1 Hard Drive Replacement: paso 4, imagen 1 de 2 Gateway SA1 Hard Drive Replacement: paso 4, imagen 2 de 2
    • Loosen the three Philips cover screws that secure the hard drive.
    • These screws cannot be fully removed from the hard drive cover.
    • Use the spudger to lift and to remove the hard drive cover.
  5. Gateway SA1 Hard Drive Replacement: paso 5, imagen 1 de 2 Gateway SA1 Hard Drive Replacement: paso 5, imagen 2 de 2
    • Slide the original hard drive to the left and lift it to remove.
    • Insert the new hard drive.
Conclusión
5 personas más completaron esta guía.
Diego Carteno
Miembro Desde 04/15/10
258 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 24-20, Regan Spring 2010 Miembro de Cal Poly, Team 24-20, Regan Spring 2010
CPSU-REGAN-S10S24G20
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 32
Todo El Tiempo: 13,910
