Introducción
The Central Processing Unit (CPU) is an integral part of your computer's speed and ability to process information. A damaged CPU may cause your computer to become slow and unstable, resulting in frequent crashes or even inability to boot. Replacing the CPU will enhance the speed and overall performance of your device. Because of its importance, it can get very expensive to replace. This simple and easy-to-follow guide that requires no special skills will walk you through the steps of replacing the CPU for a Gateway MD2614u.
Qué necesitas
Unplug the fan’s power cable, which is a group of black wires attached to a white plastic head on the motherboard.
Herramienta utilizada en este paso:Flathead 3/32" or 2.5 mm Screwdriver$5.49
The CPU is located under the heat sink you just removed.
Rotate the CPU lock 180 degrees counterclockwise with a 3.0 mm Flathead screwdriver.
2 personas más completaron esta guía.
Un comentario
Memory address registers and memory data registers together can represent the gateway?if can how?
