Introducción
removal of top case
Partes
No se requieren partes.
Flip the laptop over. Slide the battery release tab to the right.
  • Flip the laptop over. Slide the battery release tab to the right.
Agregar Comentario
Lift the battery out.
  • Lift the battery out.
Agregar Comentario
Insert spudger between sysrq and ins keys.
  • Insert spudger between sysrq and ins keys.
  • Gently lift power button panel from the right to left.
Agregar Comentario
Remove the 5 screws holding the keyboard in place.
  • Remove the 5 screws holding the keyboard in place.
Agregar Comentario
CAUTION: When lifting the keyboard out, do not lift keyboard up. Only fold back along the space bar edge. DO NOT PULL the black cable by the ribbon section; only pull it by the connector itself.
  • CAUTION: When lifting the keyboard out, do not lift keyboard up. Only fold back along the space bar edge.
  • DO NOT PULL the black cable by the ribbon section; only pull it by the connector itself.
  • Follow the black ribbon cable to the connector and gently pull straight up.
Agregar Comentario
Remove 5 screws.
  • Remove 5 screws.
  • 4 screws holding LCD hinge covers in place and 1 screw for LCD grounding.
  • Remove hinge covers.
Agregar Comentario
Gently unplug LCD from system board.
  • Gently unplug LCD from system board.
Agregar Comentario
Remove 6 screws holding LCD to hinge.
  • Remove 6 screws holding LCD to hinge.
Agregar Comentario
Pull LCD away from case.
  • Pull LCD away from case.
Agregar Comentario
Slide release and push button to eject drive
  • Slide release and push button to eject drive
  • Pull drive out.
  • When reinserting drives be sure to insert back into original slot in order to avoid interface conflicts.
Agregar Comentario
Remove 13 screws from bottom of computer
  • Remove 13 screws from bottom of computer
Agregar Comentario
Remove screws
  • Remove screws
Agregar Comentario
remove 4 screws from back of case
  • remove 4 screws from back of case
Agregar Comentario
WARNING Failure to do this step will damage mouse pad ribbon.
  • WARNING Failure to do this step will damage mouse pad ribbon.
  • Lift plug holding mouse ribbon about 1/16 inch or until it stops
  • remove ribbon
Agregar Comentario
Insert spudger between upper and lower case at drive bay closest to battery.
  • Insert spudger between upper and lower case at drive bay closest to battery.
  • Carefully and slowly go arount entire case unseating all plastic clips holding upper to lower.
Agregar Comentario
Lift upper case free about 1/4 inch
  • Lift upper case free about 1/4 inch
  • At rear of case is one last connecting wire. Unplug and remove upper case
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 20-10, Maness Fall 2010 Miembro de Cal Poly, Team 20-10, Maness Fall 2010
CPSU-MANESS-F10S20G10
3 Miembros
22 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 1,577
