Saltar al contenido principal
Gateway 600YG2 System Fan Replacement
Qué necesitas
  1. Gateway 600YG2 System Fan Replacement, Battery: paso 1, imagen 1 de 1
    • Flip the laptop over.
    • Slide the battery release tab to the right with your index finger to open the battery cover.
  2. Gateway 600YG2 System Fan Replacement: paso 2, imagen 1 de 1
    • Remove the battery cover using the tab on the right side.
    • Take the battery out with your index finger.
  3. Gateway 600YG2 System Fan Replacement, Keyboard: paso 3, imagen 1 de 1
    • Remove the 5 screws holding the keyboard in place.
  4. Gateway 600YG2 System Fan Replacement: paso 4, imagen 1 de 2 Gateway 600YG2 System Fan Replacement: paso 4, imagen 2 de 2
    • Potential for device damage: When lifting the keyboard out, do not lift the keyboard up. Only fold back along the space bar edge.
    • Potential for device damage: Do not pull the black cable by the ribbon section. Only pull it from the connector itself.
    • Follow the black ribbon cable to the connector and gently pull straight up.
  5. Gateway 600YG2 System Fan Replacement, System Fan: paso 5, imagen 1 de 2 Gateway 600YG2 System Fan Replacement, System Fan: paso 5, imagen 2 de 2
    • Unscrew the four captive screws.
    • Unplug the fan from the system and pull it out. The fan unit should slide forward before coming free.
Conclusión
Equipo
Cal Poly, Team 20-10, Maness Fall 2010 Miembro de Cal Poly, Team 20-10, Maness Fall 2010
CPSU-MANESS-F10S20G10
3 Miembros
22 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 16
Todo El Tiempo: 2,289
