Saltar al contenido principal
Gateway 600YG2 LCD Replacement
Qué necesitas
  1. Gateway 600YG2 LCD Replacement, Battery: paso 1, imagen 1 de 1
    • Flip the laptop over.
    • Slide the battery release tab to the right with your index finger to open the battery cover.
  2. Gateway 600YG2 LCD Replacement: paso 2, imagen 1 de 1
    • Remove the battery cover using the tab on the right side.
    • Take the battery out with your index finger.
  3. Gateway 600YG2 LCD Replacement, Power Button Panel: paso 3, imagen 1 de 1
    • Insert the spudger between the "sysrq" and "ins" keys.
    • Gently pry free the power button panel above the keyboard, beginning from the right and moving to the left.
  4. Gateway 600YG2 LCD Replacement, LCD: paso 4, imagen 1 de 1
    • Remove the five screws with a Phillips #0 screwdriver.
    • The LCD hinge covers are held in place by four screws. One screw is for grounding the LCD.
    • Lift the hinge covers along the outer edges with the spudger until they are released.
  5. Gateway 600YG2 LCD Replacement: paso 5, imagen 1 de 1
    • Gently unplug the LCD from the system board.
  6. Gateway 600YG2 LCD Replacement: paso 6, imagen 1 de 1
    • Using the Phillips #0 screwdriver, remove six screws that hold the LCD to the hinge.
  7. Gateway 600YG2 LCD Replacement: paso 7, imagen 1 de 1
    • Check if any cables are still connected before pulling out the LCD.
    • Remove the cable by gently pulling it out while holding down the LCD.
Conclusión
Equipo
Cal Poly, Team 20-10, Maness Fall 2010 Miembro de Cal Poly, Team 20-10, Maness Fall 2010
CPSU-MANESS-F10S20G10
3 Miembros
22 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 15
Todo El Tiempo: 1,886
