Introducción
How to remove keyboard.
Partes
No se requieren partes.
Flip the laptop over. Slide the battery release tab to the right.
  • Flip the laptop over. Slide the battery release tab to the right.
Agregar Comentario
Lift the battery out.
  • Lift the battery out.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Insert spudger between sysrq and ins keys.
  • Insert spudger between sysrq and ins keys.
  • Gently lift power button panel from the right to left.
Agregar Comentario
Remove the 5 screws holding the keyboard in place.
  • Remove the 5 screws holding the keyboard in place.
Agregar Comentario
CAUTION: When lifting the keyboard out, do not lift keyboard up. Only fold back along the space bar edge. DO NOT PULL the black cable by the ribbon section; only pull it by the connector itself.
  • CAUTION: When lifting the keyboard out, do not lift keyboard up. Only fold back along the space bar edge.
  • DO NOT PULL the black cable by the ribbon section; only pull it by the connector itself.
  • Follow the black ribbon cable to the connector and gently pull straight up.
Agregar Comentario
Conclusión
Equipo
Cal Poly, Team 20-10, Maness Fall 2010 Miembro de Cal Poly, Team 20-10, Maness Fall 2010
CPSU-MANESS-F10S20G10
3 Miembros
22 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 1,207
