Introducción
Before you begin disassembling the device, be sure the power is off.
Partes
No se requieren partes.
Wedge a plastic opening tool in between the outer frame and the rear panel assembly. Pry the outer frame off the perimeter of the rear panel assembly.
  • Wedge a plastic opening tool in between the outer frame and the rear panel assembly.
  • Pry the outer frame off the perimeter of the rear panel assembly.
  • The cover will easily pop off.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove the four #00 Phillips screws securing the front case assembly to the rear case assembly. Carefully lift, but do not completely separate, the front case assembly from the rear case assembly.
  • Remove the four #00 Phillips screws securing the front case assembly to the rear case assembly.
  • Carefully lift, but do not completely separate, the front case assembly from the rear case assembly.
  • Be extremely cautious when separating both halves, as the rear case assembly is still attached to the front case assembly via a few connectors.
Agregar Comentario
Gently pull the battery cable connector from its socket on the motherboard.
  • Gently pull the battery cable connector from its socket on the motherboard.
  • The second connector can remain attached to the motherboard, but be careful not to break the connector while handling both halves of the device.
Agregar Comentario
Conclusión
Andrew Burman
Miembro Desde 18/01/12
1 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 11-19, Maness Winter 2012 Miembro de Cal Poly, Team 11-19, Maness Winter 2012
CPSU-MANESS-W12S11G19
4 Miembros
4 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 1,268
