Introducción
If your power button is defective, replace the old one with the new power button.
Remove the barcode sticker at the bottom of the device.
  • Remove the barcode sticker at the bottom of the device.
Agregar Comentario
Remove two 8.4 mm T5 screws from the bottom of the device.
  • Remove two 8.4 mm T5 screws from the bottom of the device.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Using a plastic opening tool, carefully pry open the device. Open the device carefully, making sure not to damage the gold ribbon cable that connects the screen to the motherboard.
  • Using a plastic opening tool, carefully pry open the device.
  • Open the device carefully, making sure not to damage the gold ribbon cable that connects the screen to the motherboard.
turn the unit around
Andrew Hayden - Contestar
Since there is no replacement speaker whats the point of this process?
greg - Contestar
Very detailed set of instructions! Does anyone known the thread size of the screws in step 2? 8.4 mm T5 screws: is the length of the screw (8.4 mm) ,and the head specification (T5- size of screw driver). I need the actual thread specification. I lost one of the screws and the other one 's head is stripped. I need to replace both screws.
Harold Schultz - Contestar
Remove the power button. Remove the power button.
  • Remove the power button.
Where can I buy the button
milosvalek - Contestar
Conclusión
Timothy
Miembro Desde 26/01/12
35 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 9-3, Regan Winter 2012 Miembro de Cal Poly, Team 9-3, Regan Winter 2012
CPSU-REGAN-W12S9G3
5 Miembros
4 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 11
Últimos 30 Días: 30
Todo El Tiempo: 9,033
