Saltar al contenido principal
Garmin Nuvi 255W Logic Board Replacement
Qué necesitas
  1. Garmin Nuvi 255W Logic Board Replacement, Rear Casing: paso 1, imagen 1 de 2 Garmin Nuvi 255W Logic Board Replacement, Rear Casing: paso 1, imagen 2 de 2
    • Peel off the sticker from the bottom of the device to reveal two screws.
  2. Garmin Nuvi 255W Logic Board Replacement: paso 2, imagen 1 de 1
    • Remove two T5 Torx screws.
  3. Garmin Nuvi 255W Logic Board Replacement: paso 3, imagen 1 de 2 Garmin Nuvi 255W Logic Board Replacement: paso 3, imagen 2 de 2
    • Insert a plastic opening tool in the gap between the front and rear casing.
    • Carefully work the tool around the gap, separating the two halves of the case.
    • Keep the power switch in place while removing the rear case.
  4. Garmin Nuvi 255W Logic Board Replacement, Logic Board: paso 4, imagen 1 de 1
    • Peel away the tape holding the ribbon cable in place.
    • Disconnect the ribbon cable by using a spudger to flip up the retaining flap on its ZIF-style connector. Then gently remove the cable.
  5. Garmin Nuvi 255W Logic Board Replacement: paso 5, imagen 1 de 1
    • Pull out the cable between the logic board and the speaker to disconnect them.
  6. Garmin Nuvi 255W Logic Board Replacement: paso 6, imagen 1 de 2 Garmin Nuvi 255W Logic Board Replacement: paso 6, imagen 2 de 2
    • Remove the three screws from the logic board using the #00 Phillips screwdriver.
    • Lift the board away from the case but do not pull the logic board completely off, as it is still attached to the battery by a cable.
  7. Garmin Nuvi 255W Logic Board Replacement: paso 7, imagen 1 de 2 Garmin Nuvi 255W Logic Board Replacement: paso 7, imagen 2 de 2
    • Detach the logic board form the battery by pulling out the cable.
Conclusión
Una persona más ha completado esta guía.
Anjelica
Miembro Desde 04/11/10
564 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 25-90, Amido Spring 2010 Miembro de Cal Poly, Team 25-90, Amido Spring 2010
CPSU-AMIDO-S10S25G90
4 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 10,376
