Introducción
Use this guide to replace the battery in the Garmin Nuvi 255W.
Remove the barcode sticker at the bottom of the device.
  • Remove the barcode sticker at the bottom of the device.
Agregar Comentario
Remove two 8.4 mm T5 screws from the bottom of the device.
  • Remove two 8.4 mm T5 screws from the bottom of the device.
Agregar Comentario
Using a plastic opening tool, carefully pry open the device. Open the device carefully, making sure not to damage the gold ribbon cable that connects the screen to the motherboard.
  • Using a plastic opening tool, carefully pry open the device.
  • Open the device carefully, making sure not to damage the gold ribbon cable that connects the screen to the motherboard.
turn the unit around
Andrew Hayden - Contestar
Since there is no replacement speaker whats the point of this process?
greg - Contestar
Very detailed set of instructions! Does anyone known the thread size of the screws in step 2? 8.4 mm T5 screws: is the length of the screw (8.4 mm) ,and the head specification (T5- size of screw driver). I need the actual thread specification. I lost one of the screws and the other one 's head is stripped. I need to replace both screws.
Harold Schultz - Contestar
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Remove the power button. Remove the power button.
  • Remove the power button.
Where can I buy the button
milosvalek - Contestar
Unscrew the four 6.70 mm screws holding the motherboard in place using a philips #0 screw driver.
  • Unscrew the four 6.70 mm screws holding the motherboard in place using a philips #0 screw driver.
Agregar Comentario
Lift up the motherboard. Carefully disconnect the battery and motherboard.  Slowly wiggling the connection makes it easier to disconnect the battery from the motherboard.
  • Lift up the motherboard.
  • Carefully disconnect the battery and motherboard. Slowly wiggling the connection makes it easier to disconnect the battery from the motherboard.
Agregar Comentario
Using the plastic opening tool as a wedge, pry the battery from the case.  This can be fairly tough as the battery is glued to the case.  Don't be afraid to use force and some good leverage. Using the plastic opening tool as a wedge, pry the battery from the case.  This can be fairly tough as the battery is glued to the case.  Don't be afraid to use force and some good leverage.
  • Using the plastic opening tool as a wedge, pry the battery from the case. This can be fairly tough as the battery is glued to the case. Don't be afraid to use force and some good leverage.
Agregar Comentario
Conclusión
5 personas más completaron esta guía.
Timothy
Miembro Desde 26/01/12
35 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 9-3, Regan Winter 2012 Miembro de Cal Poly, Team 9-3, Regan Winter 2012
CPSU-REGAN-W12S9G3
5 Miembros
4 Guías creadas
Thanks for this very nicely illustrated guide.
RBStorms - Contestar
Thanks for the guide. Used it to open up a Nuvi 265 because the battery had been left to discharge below the protection circuit's limit. Connected the battery leads (Green = ground, Red = voltage, Black = temperature) to a 5v USB charger for ~20 seconds to revive the protection circuit, and the unit is now charging again. If you're going to do this, know the risks. Thermal runaways in lithium batteries can be extremely volatile.
rbol - Contestar
Used these instructions to replace battery in my 5-year old Garmin nuvi 205W (which has the same access and internal geometry).
JRedmond - Contestar
Thanks, great demonstration.
peter2x4 - Contestar
This is great! I have run into a big problem, though. One of the screws is "unthreaded." The head has become smooth, and I can't unscrew it to get the cover off. Is there any way to get it off???
nancyw - Contestar
There are screw bits made specially to extract stripped screws, but if the screw isn't too far below the surface it's going through, the cheap way is to file or grind a slot into the head so you can extract it with a jeweller's flathead.
rbol -
Kein Problem, keine 10 Minuten gebraucht, um im nüvi 255W den Akku zu wechseln!
w.gerrit - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 6
Últimos 7 Días: 39
Últimos 30 Días: 148
Todo El Tiempo: 21,878
