Saltar al contenido principal
Garmin Nuvi 200 Speaker Replacement
Qué necesitas
  1. Garmin Nuvi 200 Speaker Replacement, Rear Casing: paso 1, imagen 1 de 2 Garmin Nuvi 200 Speaker Replacement, Rear Casing: paso 1, imagen 2 de 2
    • Peel off the sticker from the bottom of the device to reveal two screws.
  2. Garmin Nuvi 200 Speaker Replacement: paso 2, imagen 1 de 1
    • Remove two T5 Torx screws.
  3. Garmin Nuvi 200 Speaker Replacement: paso 3, imagen 1 de 2 Garmin Nuvi 200 Speaker Replacement: paso 3, imagen 2 de 2
    • Insert a plastic opening tool in the gap between the front and rear casing.
    • Carefully work the tool around the gap, separating the two halves of the case.
    • Keep the power switch in place while removing the rear case.
  4. Garmin Nuvi 200 Speaker Replacement, Speaker: paso 4, imagen 1 de 1
    • Unscrew the two screws on opposite sides of the speaker using the #00 Phillips screwdriver.
  5. Garmin Nuvi 200 Speaker Replacement: paso 5, imagen 1 de 1
    • Pull the cable out to detach the speaker from the logic board.
  6. Garmin Nuvi 200 Speaker Replacement: paso 6, imagen 1 de 3 Garmin Nuvi 200 Speaker Replacement: paso 6, imagen 2 de 3 Garmin Nuvi 200 Speaker Replacement: paso 6, imagen 3 de 3
    • Wedge the iPod opener into the space between the speaker and the case.
    • Apply pressure to pry the speaker away from the case.
Conclusión
3 personas más completaron esta guía.
Anjelica
Miembro Desde 04/11/10
564 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 25-90, Amido Spring 2010 Miembro de Cal Poly, Team 25-90, Amido Spring 2010
CPSU-AMIDO-S10S25G90
4 Miembros
9 Guías creadas
2 comentarios
just a note i had a problem with the speaker in my nuvi 200 an upon opening up found speaker plug had come loose i guess from being dropped a few times pushed plug in an works fine please check all connections before replacing your speaker saved me $$ thanks for a great site everyone...
randaleholland - Contestar
Where can you buy replacement speakers for the Garmin units?
Brat Fry - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 13
Todo El Tiempo: 7,060
