Introducción
Sometimes the buttons on the device may stick or become unresponsive, requiring replacement. This guide shows how to replace buttons on the Game Boy Color.
Locate the battery compartment on the back of the Game Boy Color. Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
  • Locate the battery compartment on the back of the Game Boy Color.
  • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
Agregar Comentario
Remove the batteries from the battery compartment.
  • Remove the batteries from the battery compartment.
Agregar Comentario
Using a Y1 screwdriver, remove the six screws on the back of the device as pictured.  The bottom two screws are located inside of the battery compartment.
  • Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
Agregar Comentario
Gently lift and separate the back housing from the rest of the device.  Now you've got the back housing out! Gently lift and separate the back housing from the rest of the device.  Now you've got the back housing out!
  • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing out!
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Push up on the tabs on either side of the ribbon with a spudger.
  • Push up on the tabs on either side of the ribbon with a spudger.
Agregar Comentario
Gently remove the ribbon cable from the port
  • Gently remove the ribbon cable from the port
Agregar Comentario
Using the Phillips #1 screwdriver, remove the 3 screws shown in the picture. Using the Phillips #1 screwdriver, remove the 3 screws shown in the picture.
  • Using the Phillips #1 screwdriver, remove the 3 screws shown in the picture.
Agregar Comentario
Gently lift the motherboard from the front housing.
  • Gently lift the motherboard from the front housing.
Agregar Comentario
Remove the rubber backing on each button grouping.
  • Remove the rubber backing on each button grouping.
Agregar Comentario
Remove the original buttons from the housing.
  • Remove the original buttons from the housing.
Agregar Comentario
Conclusión
11 personas más completaron esta guía.
Equipo
Cal Poly, Team 19-47, Regan Winter 2013 Miembro de Cal Poly, Team 19-47, Regan Winter 2013
CPSU-REGAN-W13S19G47
4 Miembros
24 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 7
Últimos 7 Días: 29
Últimos 30 Días: 191
Todo El Tiempo: 14,365
