Introducción
Use this repair guide in order to replace the speakers.
Take the battery cover off by releasing the locking tab and hinging the cover away. Take the battery cover off by releasing the locking tab and hinging the cover away. Take the battery cover off by releasing the locking tab and hinging the cover away.
  • Take the battery cover off by releasing the locking tab and hinging the cover away.
Agregar Comentario
Remove the six back panel screws using a Tri-wing Screwdriver.
  • Remove the six back panel screws using a Tri-wing Screwdriver.
Agregar Comentario
Remove bottom back panel screw with a Phillips #1 screw driver.
  • Remove bottom back panel screw with a Phillips #1 screw driver.
We recommend you change the the screw head to a Phillips 1 so you don't strip the screw. (Something we experienced)
Adriano Agostino - Contestar
Remove the back panel by pulling away with one hand and the front secured in the other hand.
  • Remove the back panel by pulling away with one hand and the front secured in the other hand.
  • Removal of the back panel may cause shoulder buttons and side panels to come loose and fall off.
Agregar Comentario
Remove left and right triggers by lifting and pulling them away from the system. Do the same for side panels
  • Remove left and right triggers by lifting and pulling them away from the system.
  • Do the same for side panels
  • For finicky or jammed triggers only. Adjust and correct triggers and reassemble. Most jammed triggers are caused by buttons misplaced or jammed in its enclosure.
Agregar Comentario
Remove the gray On/Off Switch by pulling up and away from the unit. Replace with another switch if necessary.
  • Remove the gray On/Off Switch by pulling up and away from the unit. Replace with another switch if necessary.
Agregar Comentario
Remove the rubber button pads from their pockets. Remove the plastic buttons and the D-pad from beneath the rubber pads with tweezers or by hand. Remove the plastic buttons and the D-pad from beneath the rubber pads with tweezers or by hand.
  • Remove the rubber button pads from their pockets.
  • Remove the plastic buttons and the D-pad from beneath the rubber pads with tweezers or by hand.
Agregar Comentario
Using the tweezers, gently pull the ribbon from the logic board. Using the tweezers, gently pull the ribbon from the logic board. Using the tweezers, gently pull the ribbon from the logic board.
  • Using the tweezers, gently pull the ribbon from the logic board.
Agregar Comentario
Slightly move the speaker to the right and desolder the two wires from the logic board. Beware of over heating the soldering kit will damage the logic board. Beware of over heating the soldering kit will damage the logic board.
  • Slightly move the speaker to the right and desolder the two wires from the logic board.
  • Beware of over heating the soldering kit will damage the logic board.
Agregar Comentario
Linea de Meta
7 personas más completaron esta guía.
Adam
Miembro Desde 20/01/10
628 Reputación
10 Guías creadas
Equipo
Cal Poly, Team 16-29, Maness Winter 2010 Miembro de Cal Poly, Team 16-29, Maness Winter 2010
CPSU-MANESS-W10S16G29
5 Miembros
26 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 18
Últimos 30 Días: 49
Todo El Tiempo: 7,340
