Saltar al contenido principal
Game Boy Advance Screen Replacement
Qué necesitas
Resumen del Video
  1. Game Boy Advance Screen Replacement, Game Boy Advance Teardown: paso 1, imagen 1 de 3 Game Boy Advance Screen Replacement, Game Boy Advance Teardown: paso 1, imagen 2 de 3 Game Boy Advance Screen Replacement, Game Boy Advance Teardown: paso 1, imagen 3 de 3
    • Remove the back battery cover by pinching down on the tab and pulling outward.
  2. Game Boy Advance Screen Replacement: paso 2, imagen 1 de 1
    • Remove the six back panel screws using a Y1 screw driver.
  3. Game Boy Advance Screen Replacement: paso 3, imagen 1 de 1
    • Remove bottom back panel screw with a Phillips #1 screw driver.
  4. Game Boy Advance Screen Replacement: paso 4, imagen 1 de 1
    • Remove the back panel by pulling away with one hand and the front secured in the other hand.
    • Beware of right and left triggers, the right and left panels, and the power switch falling off as the back panel is removed.
  5. Game Boy Advance Screen Replacement: paso 5, imagen 1 de 2 Game Boy Advance Screen Replacement: paso 5, imagen 2 de 2
    • Remove left and right triggers by lifting and pulling them away from the system.
    • Do the same for side panels.
    • For finicky or jammed triggers only. Adjust and correct triggers and reassemble. Most jammed triggers are caused by buttons misplaced or jammed in its enclosure.
  6. Game Boy Advance Screen Replacement: paso 6, imagen 1 de 2 Game Boy Advance Screen Replacement: paso 6, imagen 2 de 2
    • Remove the gray On/Off Switch by pulling up and away from the unit. Replace with another switch if necessary.
  7. Game Boy Advance Screen Replacement: paso 7, imagen 1 de 1
    • Remove the three screws on the circuit board with a Phillips #1 screw driver.
    • The last screw on the right is not included on some Game Boy Advance systems.
  8. Game Boy Advance Screen Replacement: paso 8, imagen 1 de 2 Game Boy Advance Screen Replacement: paso 8, imagen 2 de 2
    • Pull circuit board away from the front panel by pulling up at the bottom of the circuit board, keeping the top ribbon still connected.
    • Beware not to damage the top ribbon by pulling up gently.
  9. Game Boy Advance Screen Replacement: paso 9, imagen 1 de 3 Game Boy Advance Screen Replacement: paso 9, imagen 2 de 3 Game Boy Advance Screen Replacement: paso 9, imagen 3 de 3
    • Remove the rubber button pads from their pockets.
    • Remove the plastic buttons and the D-pad from beneath the rubber pads with tweezers or by hand.
  10. Game Boy Advance Screen Replacement: paso 10, imagen 1 de 3 Game Boy Advance Screen Replacement: paso 10, imagen 2 de 3 Game Boy Advance Screen Replacement: paso 10, imagen 3 de 3
    • Use a spudger/tweezers/fingernail to unlatch the LCD ribbon port by pulling the grey tabs on the sides upwards (towards the top edge of the PCB).
    • Once the LCD ribbon port has been unlatched, the LCD ribbon should very easily slide out and can be removed with zero force using fingers or tweezers.
  11. Game Boy Advance Screen Replacement: paso 11, imagen 1 de 3 Game Boy Advance Screen Replacement: paso 11, imagen 2 de 3 Game Boy Advance Screen Replacement: paso 11, imagen 3 de 3
    • Use the spudger to lift the screen from the front panel. Place the spudger in the space directly left of the D-pad.
    • The screen and the front panel is connected by a black tape that could rip if not removed carefully.
    • You can use an iOpener or a hair dryer on the other side of the front panel in order to soften the black tape.
  12. Game Boy Advance Screen Replacement: paso 12, imagen 1 de 1
    • Use the tweezers to remove the black tape if needed.
Linea de Meta
18 personas más completaron esta guía.
Adam
Miembro Desde 01/20/10
815 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 16-29, Maness Winter 2010 Miembro de Cal Poly, Team 16-29, Maness Winter 2010
CPSU-MANESS-W10S16G29
5 Miembros
61 Guías creadas
6 comentarios
Doesn't say where you can get new screen !!!!??
andrew Davies - Contestar
Doesn't say where to get screen from !!!??
Do this with the Game Boy Advance SP please!
Santi12008 - Contestar
It does not say where you can get a new screen
criscaanca - Contestar
DONT DO THIS LIKE THAT!!!. The area of the screen in the space beside the D-pad is the only area where the LCD glass is completely exposed. It’s Literaly the WORST place to apply pressure, 99% chances for the LCD to break. There is a notch on the top right corner and another under the ribbon cable. Making your way from the top right to the left is far more safe.
Flyingmcintosh - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 15
Ultimos 7 días: 133
Ultimos 30 días: 505
Todo El Tiempo: 38,184
