Saltar al contenido principal
Game Boy Advance On/Off Switch Replacement
Qué necesitas
  1. Game Boy Advance On/Off Switch Replacement, Remove the Battery Cover/Batteries: paso 1, imagen 1 de 3 Game Boy Advance On/Off Switch Replacement, Remove the Battery Cover/Batteries: paso 1, imagen 2 de 3 Game Boy Advance On/Off Switch Replacement, Remove the Battery Cover/Batteries: paso 1, imagen 3 de 3
    • Take the battery cover off by releasing the locking tab and hinging the cover away. Remove the batteries inside the cover
    • Do not forget to remove the batteries! This applies to working with any electronic device as working with live electricity may damage the device or cause malfunctions
  2. Game Boy Advance On/Off Switch Replacement, Unscrew the Back Panel: paso 2, imagen 1 de 2 Game Boy Advance On/Off Switch Replacement, Unscrew the Back Panel: paso 2, imagen 2 de 2
    • Remove the six back panel screws using a Tri-wing Screwdriver.
    • Remove bottom back panel screw with a Phillips #1 screw driver. (Image #2)
  3. Game Boy Advance On/Off Switch Replacement, Remove the Back Panel: paso 3, imagen 1 de 1
    • Remove the back panel by pulling away with one hand and the front secured in the other hand.
    • Removal of the back panel may cause shoulder buttons and side panels to come loose and fall off.
  4. Game Boy Advance On/Off Switch Replacement, Remove Triggers: paso 4, imagen 1 de 2 Game Boy Advance On/Off Switch Replacement, Remove Triggers: paso 4, imagen 2 de 2
    • Remove left and right triggers by lifting and pulling them away from the system.
    • Do the same for side panels
    • For finicky or jammed triggers only! Adjust and correct triggers and reassemble. Most jammed triggers are caused by buttons misplaced or jammed in its enclosure.
  5. Game Boy Advance On/Off Switch Replacement, Remove the On/Off Switch: paso 5, imagen 1 de 1
    • Remove the gray On/Off Switch by pulling up and away from the unit. Replace with another switch if necessary.
Conclusión
4 personas más completaron esta guía.
Adam
Miembro Desde 01/20/10
807 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 16-29, Maness Winter 2010 Miembro de Cal Poly, Team 16-29, Maness Winter 2010
CPSU-MANESS-W10S16G29
5 Miembros
61 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 30
Ultimos 30 días: 132
Todo El Tiempo: 19,654
