Saltar al contenido principal
Galaxy Tab S 10.5 Battery Replacement
Qué necesitas
  1. Galaxy Tab S 10.5 Battery Replacement, Disassembling Galaxy Tab S 10.5 Back Cover: paso 1, imagen 1 de 2 Galaxy Tab S 10.5 Battery Replacement, Disassembling Galaxy Tab S 10.5 Back Cover: paso 1, imagen 2 de 2
    • Place the plastic opening tool into the SD card slot or charge port.
    • Try in an upward motion until you see a separation between the tablet and back cover.
  2. Galaxy Tab S 10.5 Battery Replacement: paso 2, imagen 1 de 1
    • Work around the entire device by sliding the plastic opening tool around the rim.
    • If this is the first time, it will be hard to separate the back cover from the tablet.
    • The clips are approximately 5 cm apart. While working around the device, the clips will make a dislocating sound when disconnected.
  3. Galaxy Tab S 10.5 Battery Replacement: paso 3, imagen 1 de 1
    • Remove the back cover once all links have been separated.
    • Be careful when touching any of the internal components of the tablet.
  4. Galaxy Tab S 10.5 Battery Replacement, Battery: paso 4, imagen 1 de 3 Galaxy Tab S 10.5 Battery Replacement, Battery: paso 4, imagen 2 de 3 Galaxy Tab S 10.5 Battery Replacement, Battery: paso 4, imagen 3 de 3
    • Using tweezers, peel back the green tape from the ZIF connectors on the two black ribbon cables.
    • Use a plastic opening tool to lift up the plastic clips on the ZIF connectors.
  5. Galaxy Tab S 10.5 Battery Replacement: paso 5, imagen 1 de 1
    • Remove the six 2mm screws Phillips #000 screws surrounding the battery.
  6. Galaxy Tab S 10.5 Battery Replacement: paso 6, imagen 1 de 3 Galaxy Tab S 10.5 Battery Replacement: paso 6, imagen 2 de 3 Galaxy Tab S 10.5 Battery Replacement: paso 6, imagen 3 de 3
    • Place the plastic opening tool between the frame and battery.
    • Move the plastic opening tool in a downward motion, away from the battery to bring the battery out of the device.
  7. Galaxy Tab S 10.5 Battery Replacement: paso 7, imagen 1 de 3 Galaxy Tab S 10.5 Battery Replacement: paso 7, imagen 2 de 3 Galaxy Tab S 10.5 Battery Replacement: paso 7, imagen 3 de 3
    • Hold the battery and disconnect the plug to remove the battery.
Conclusión
82 personas más completaron esta guía.
Jordan Soto
Miembro Desde 08/26/15
3,249 Reputación
6 Guías creadas
Equipo
USF Tampa, Team 3-2, Eyestone Fall 2015 Miembro de USF Tampa, Team 3-2, Eyestone Fall 2015
USFT-EYESTONE-F15S3G2
3 Miembros
20 Guías creadas
19 comentarios
where is a good place to buy a replacement battery?
brianference - Contestar
Artículo muy positivo: pasos muy bien detallados. Me ha resultado fácil la el cambio de batería. Gracias por tu colaboración.
Miguel Ángel - Contestar
Bought mine off of ebay
Jerry Belschner - Contestar
Great guide! Thanks a lot!
Markus - Contestar
I bought a battery but am afraid to do the replacement myself. Where can I take the tablet to have it done?
Barb - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 68
Ultimos 30 días: 275
Todo El Tiempo: 98,555
