Saltar al contenido principal
GE A1050 LCD Replacement
Qué necesitas
  1. GE A1050 LCD Replacement, LCD: paso 1, imagen 1 de 3 GE A1050 LCD Replacement, LCD: paso 1, imagen 2 de 3 GE A1050 LCD Replacement, LCD: paso 1, imagen 3 de 3
    • Remove the batteries, hand strap, and memory card if so equipped.
    • Remove the two Phillips screws from the bottom.
    • Remove the two Phillips screws from the left side.
  2. GE A1050 LCD Replacement: paso 2, imagen 1 de 3 GE A1050 LCD Replacement: paso 2, imagen 2 de 3 GE A1050 LCD Replacement: paso 2, imagen 3 de 3
    • Remove the two screws from the right side.
    • The two screws from the left side are shorter than the ones from the right. Keep those separated.
    • Start splitting the case from the battery compartment to the sides. No special tool is needed to split the case.
  3. GE A1050 LCD Replacement: paso 3, imagen 1 de 3 GE A1050 LCD Replacement: paso 3, imagen 2 de 3 GE A1050 LCD Replacement: paso 3, imagen 3 de 3
    • Do not remove the back side of the case, just flip it over. The speaker is connected by wires to the main body, but positioned in the back case.
    • Flip the LCD to the bottom. You can not yet remove it, because it is still attached to the board.
    • The LCD cable is held into the connector via some compression clips. Move both ends carefully away from the connector, toward the LCD.
    • The clips only move about an 1/8 of an inch. Be careful not to use too much force.
  4. GE A1050 LCD Replacement: paso 4, imagen 1 de 1
    • After exchanging the LCD for a new one, and after reassembling your camera, you should have a working LCD.
Conclusión
Una persona más ha completado esta guía.
oldturkey03
Miembro Desde 09/29/10
782,427 Reputación
119 Guías creadas
Equipo
Global Fixers Miembro de Global Fixers
Community
33 Miembros
544 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 13
Todo El Tiempo: 1,740
