Partes
No se requieren partes.
Locate and remove the 14.5 mm Phillips #1 screw on the bottom of the fan base.
  • Locate and remove the 14.5 mm Phillips #1 screw on the bottom of the fan base.
Agregar Comentario
Locate the gray base support release tabs found on either side pictured in the first image. There are release tabs on each side of the base.
  • Locate the gray base support release tabs found on either side pictured in the first image.
    • There are release tabs on each side of the base.
  • Press both release tabs in with the tip of your fingers and pull the gray base support until the tabs are cleared.
Agregar Comentario
Continue removing the gray base support by pressing your thumb into the circular opening in the base and pulling with your figures on the back side.
  • Continue removing the gray base support by pressing your thumb into the circular opening in the base and pulling with your figures on the back side.
  • Notice that on the internal front tip of the base there is a tab. Because of this tab the back end will pivot off at that point.
Agregar Comentario
After the base has separated more it will be easy to fully remove it. Continue pulling the back edge of the gray base support, rotating it around the front tab until it comes off completely.
  • After the base has separated more it will be easy to fully remove it. Continue pulling the back edge of the gray base support, rotating it around the front tab until it comes off completely.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove the following five 14.5 mm Phillips #1 screws found on the bottom.
  • Remove the following five 14.5 mm Phillips #1 screws found on the bottom.
    • All of the screws are recessed by 17.5 mm, so ensure your screwdriver can reach that far.
Agregar Comentario
Once all five screws have been removed the base cover should fall right off with out any effort.
  • Once all five screws have been removed the base cover should fall right off with out any effort.
  • When putting the base cover back on; be careful to make sure that none of the wires are pinched.
Agregar Comentario
Remove the two 15 mm Phillips screws on the retention plate.
  • Remove the two 15 mm Phillips screws on the retention plate.
  • The tan retention plate will fall off once the screws are removed.
Agregar Comentario
Take the 1.5 mm Flathead Screwdriver, or any thin elongated tool that fits into the semi-circular holes along side the AC power cord white wire. Press into the hole gently to release the grip on the wire.
  • Take the 1.5 mm Flathead Screwdriver, or any thin elongated tool that fits into the semi-circular holes along side the AC power cord white wire. Press into the hole gently to release the grip on the wire.
  • The AC power cord wire should release with ease if done properly.
Agregar Comentario
Cut the existing cable tie bundling the other AC power cord, red, orange, gray, and blue wires together.
  • Cut the existing cable tie bundling the other AC power cord, red, orange, gray, and blue wires together.
  • Remove or cut the crimp connector connecting the blue wire and the AC power cord wire.
Agregar Comentario
Take the new AC power cord and follow the steps in reverse order.
  • Take the new AC power cord and follow the steps in reverse order.
    • It will help to use a soldering iron to solder the tip of the wire that gets inserted into the power/speed switch.
    • You may need a new cable tie and wire terminator with the new power cord.
Agregar Comentario
Conclusión
3 personas más completaron esta guía.
Chris Hartley
Miembro Desde 04/10/12
355 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 24-28, Regan Fall 2012 Miembro de Cal Poly, Team 24-28, Regan Fall 2012
CPSU-REGAN-F12S24G28
4 Miembros
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 8
Todo El Tiempo: 936
