Turn locking device on back side of phone marked by the rectangle counter clockwise. Turn locking device on back side of phone marked by the rectangle counter clockwise.
  • Turn locking device on back side of phone marked by the rectangle counter clockwise.
Agregar Comentario
Remove battery by grabbing the sides and pulling upward.
  • Remove battery by grabbing the sides and pulling upward.
  • If battery was malfunctioning due to age or corrosion, there may be battery acid residue on the battery and the back of the phone. Wear gloves in order to prevent skin irritation.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove back cover by taking out the four, five point star screws indicated in the picture. A 1.5mm flathead screwdriver can be used to remove the screws. Once all screws are removed the case will easily lift off. Once all screws are removed the case will easily lift off.
  • Remove back cover by taking out the four, five point star screws indicated in the picture. A 1.5mm flathead screwdriver can be used to remove the screws.
  • Once all screws are removed the case will easily lift off.
Agregar Comentario
With the back cover removed, the antenna is now exposed. To remove it, take out the phillips screw holding it in place. With the back cover removed, the antenna is now exposed. To remove it, take out the phillips screw holding it in place.
  • With the back cover removed, the antenna is now exposed. To remove it, take out the phillips screw holding it in place.
Agregar Comentario
With screw removed, gently pull the antenna outward. It should slide out easily. With screw removed, gently pull the antenna outward. It should slide out easily.
  • With screw removed, gently pull the antenna outward. It should slide out easily.
Agregar Comentario
Conclusión
troy
Miembro Desde 11/03/13
1 Reputación
4 Guías creadas
Equipo
Clemson, Team 13-3, Benson Spring 2013 Miembro de Clemson, Team 13-3, Benson Spring 2013
CLEM-BENSON-S13S13G3
3 Miembros
14 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 336
