Introducción
There are two LCD displays on this phone. When the phone is opened, the inside display has a cover with a piece of protective glass glued to it. Since this phone is designed to be water-resistant, breaking the factory seal made by the glue is not recommended as it may expose the inner electronics to moisture. This guide treats the glass and cover as a single part.
Partes
No se requieren partes.
There are 4 black screws that need to be removed on the top of the lid.  A 1.5mm flathead screwdriver will work on the star shaped screw heads.
  • There are 4 black screws that need to be removed on the top of the lid. A 1.5mm flathead screwdriver will work on the star shaped screw heads.
  • Make note that two of the screws closest to the hinge are longer than the other two.
Agregar Comentario
Remove the two side screws. When reassembling you may need to press the front and back of the lid together when inserting these side screws so that the holes align.
  • Remove the two side screws.
  • When reassembling you may need to press the front and back of the lid together when inserting these side screws so that the holes align.
Agregar Comentario
Use a plastic opening tool to remove the screen cover from the rest of the lid. Use a plastic opening tool to remove the screen cover from the rest of the lid.
  • Use a plastic opening tool to remove the screen cover from the rest of the lid.
Agregar Comentario
Your phone should look like the picture to the left. If reassembling from a previous step make sure the ribbon cable is properly situated before securing the front cover.
  • Your phone should look like the picture to the left.
  • If reassembling from a previous step make sure the ribbon cable is properly situated before securing the front cover.
Agregar Comentario
Conclusión
To disassemble your device, follow these instructions in reverse order.
Equipo
Clemson, Team 13-3, Benson Spring 2013 Miembro de Clemson, Team 13-3, Benson Spring 2013
CLEM-BENSON-S13S13G3
3 Miembros
14 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 360
