Saltar al contenido principal
Furby "Feet" Cleaning Guide
Qué necesitas
  1. Furby "Feet" Cleaning Guide, Furby "Feet" Cleaning Guide: paso 1, imagen 1 de 3 Furby "Feet" Cleaning Guide, Furby "Feet" Cleaning Guide: paso 1, imagen 2 de 3 Furby "Feet" Cleaning Guide, Furby "Feet" Cleaning Guide: paso 1, imagen 3 de 3
    • Flip Furby upside down so his feet are pointed towards you.
    • Unscrew the right and left screws on the base.
  2. Furby "Feet" Cleaning Guide: paso 2, imagen 1 de 3 Furby "Feet" Cleaning Guide: paso 2, imagen 2 de 3 Furby "Feet" Cleaning Guide: paso 2, imagen 3 de 3
    • Remove the base from your Furby.
    • Flip over the base so the screws are on the right and left.
    • Unscrew the 2 right and 2 left inside screws.
  3. Furby "Feet" Cleaning Guide: paso 3, imagen 1 de 3 Furby "Feet" Cleaning Guide: paso 3, imagen 2 de 3 Furby "Feet" Cleaning Guide: paso 3, imagen 3 de 3
    • Lift the housing for the foot components.
    • Rotate the base 90 degrees.
    • Locate all four of the foot activation levers. Remove them one by one from the base.
  4. Furby "Feet" Cleaning Guide: paso 4, imagen 1 de 2 Furby "Feet" Cleaning Guide: paso 4, imagen 2 de 2
    • Locate the feet pieces and remove them.
  5. Furby "Feet" Cleaning Guide: paso 5, imagen 1 de 3 Furby "Feet" Cleaning Guide: paso 5, imagen 2 de 3 Furby "Feet" Cleaning Guide: paso 5, imagen 3 de 3
    • Locate and gently lift out the four small springs using tweezers.
    • Now that you have all parts are removed, they can be cleaned and reassembled into Furby's "feet".
Conclusión
Equipo
Cal Poly, Team 15-5, Livingston Fall 2016 Miembro de Cal Poly, Team 15-5, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G5
4 Miembros
9 Guías creadas
Un comentario
I greet my furby boom 2012 he falls asleep and when I wake him up he starts to cry and then he falls asleep. This started after a week without using.What I can do,Thanks for your help.Juan
jrrabrito - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 11
Todo El Tiempo: 1,402
