Partes
No se requieren partes.
Turn the laptop over so that the bottom of the laptop faces you.
  • Turn the laptop over so that the bottom of the laptop faces you.
Agregar Comentario
Locate the hard drive cover and remove the screw. Locate the hard drive cover and remove the screw.
  • Locate the hard drive cover and remove the screw.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Now you can use your finger to pull the cover off. Now you can use your finger to pull the cover off.
  • Now you can use your finger to pull the cover off.
Agregar Comentario
Pull on the pull tab to release the hard drive. Now you can take the hard drive out of the laptop. Now you can take the hard drive out of the laptop.
  • Pull on the pull tab to release the hard drive.
  • Now you can take the hard drive out of the laptop.
Agregar Comentario
There is a screw on each corner of the hard drive bracket. To take the hard drive out of its bracket you need to remove the 4 screws. Do not take the screws out of the hard drive itself, only from the bracket. With the screws removed the drive slides out of the bracket.
  • There is a screw on each corner of the hard drive bracket. To take the hard drive out of its bracket you need to remove the 4 screws.
  • Do not take the screws out of the hard drive itself, only from the bracket.
  • With the screws removed the drive slides out of the bracket.
  • Now you can replace the hard drive with a new one.
Agregar Comentario
Conclusión
3 personas más completaron esta guía.
storm
Miembro Desde 07/07/12
479 Reputación
2 Guías creadas
Please I need a password protection my computer is locked I need a code to unlock my computer pls Esprimo mobile V5515 please help me
sadik G Ibrahim - Contestar
Is it a Windows password or a BIOS password?
storm -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 17
Todo El Tiempo: 3,031
