Introducción
Accessing the RAM in this computer is straightforward and requires minimal disassembly.
Partes
No se requieren partes.
Locate the two clips on the bottom of the computer that support the battery.
  • Locate the two clips on the bottom of the computer that support the battery.
Agregar Comentario
Using your fingers,  push the clips inward and then upward.
  • Using your fingers, push the clips inward and then upward.
  • Lift the battery out of the computer.
Agregar Comentario
Locate the RAM cover.
  • Locate the RAM cover.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove the screw labeled “3.”
  • Remove the screw labeled “3.”
  • The screw is not shown in the picture.
Agregar Comentario
Remove the RAM cover by lifting it with your finger. Remove the RAM cover by lifting it with your finger.
  • Remove the RAM cover by lifting it with your finger.
Agregar Comentario
Remove the RAM module by pushing the securing clips outward. The RAM module will then slightly pop out.
  • Remove the RAM module by pushing the securing clips outward.
  • The RAM module will then slightly pop out.
  • When you are installing a new RAM module, carefully insert it into the socket and push downwards.
Agregar Comentario
Carefully pull the RAM module from the computer. Carefully pull the RAM module from the computer.
  • Carefully pull the RAM module from the computer.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Neil Daniels
Miembro Desde 17/01/11
1,267 Reputación
11 Guías creadas
Equipo
Cal Poly, Team 5-18, Amido Winter 2011 Miembro de Cal Poly, Team 5-18, Amido Winter 2011
CPSU-AMIDO-W11S5G18
3 Miembros
11 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 8
Todo El Tiempo: 2,737
