Saltar al contenido principal
Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement
Qué necesitas
  1. Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement, Battery: paso 1, imagen 1 de 1
    • Locate the two clips on the bottom of the computer that support the battery.
  2. Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: paso 2, imagen 1 de 1
    • Using your fingers, push the clips inward and then upward.
    • Lift the battery out of the computer.
  3. Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement, Hinge Cover: paso 3, imagen 1 de 3 Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement, Hinge Cover: paso 3, imagen 2 de 3 Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement, Hinge Cover: paso 3, imagen 3 de 3
    • Use a spudger to lift the back of the hinge cover on the left and right sides of the computer.
  4. Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: paso 4, imagen 1 de 1
    • Lay the computer flat on a stable surface with the monitor pointing away from you.
  5. Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: paso 5, imagen 1 de 3 Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: paso 5, imagen 2 de 3 Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: paso 5, imagen 3 de 3
    • Use a spudger to partially lift the hinge cover.
  6. Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: paso 6, imagen 1 de 2 Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: paso 6, imagen 2 de 2
    • The hinge cover has a ribbon cable that is attached to the motherboard. To prevent damage, lift the hinge cover slowly.
    • Lift the hinge cover enough to expose the ribbon cable.
  7. Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: paso 7, imagen 1 de 2 Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: paso 7, imagen 2 de 2
    • Disconnect the ribbon cable from the motherboard and remove the hinge cover from the computer.
  8. Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement, Keyboard: paso 8, imagen 1 de 3 Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement, Keyboard: paso 8, imagen 2 de 3 Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement, Keyboard: paso 8, imagen 3 de 3
    • The keyboard has a ribbon cable that is attached to the motherboard. To prevent damage, lift keyboard slowly.
    • Lift the keyboard enough to expose the ribbon cable.
  9. Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: paso 9, imagen 1 de 2 Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: paso 9, imagen 2 de 2
    • Use a spudger to release the ribbon cable from the motherboard.
  10. Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: paso 10, imagen 1 de 2 Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: paso 10, imagen 2 de 2
    • After the ribbon has been detached, carefully remove the keyboard.
  11. Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement, Metal Motherboard Cover: paso 11, imagen 1 de 1
    • Remove the following screws, all labeled "3."
    • Two 8.63mm screws.
    • One 7.65mm screw.
    • One 5.74mm screw.
    • Remove the following screw, labeled "15."
    • One 17.81mm screw.
  12. Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: paso 12, imagen 1 de 3 Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: paso 12, imagen 2 de 3 Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: paso 12, imagen 3 de 3
    • Lift the cover with fingers and remove.
Conclusión
Neil Daniels
Miembro Desde 01/17/11
1,411 Reputación
11 Guías creadas
Equipo
Cal Poly, Team 5-18, Amido Winter 2011 Miembro de Cal Poly, Team 5-18, Amido Winter 2011
CPSU-AMIDO-W11S5G18
3 Miembros
22 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 3,611
