Introducción
The hinge cover has the computer power button, wireless switch, and volume toggle.
Locate the two clips on the bottom of the computer that support the battery.
  • Locate the two clips on the bottom of the computer that support the battery.
Agregar Comentario
Using your fingers,  push the clips inward and then upward.
  • Using your fingers, push the clips inward and then upward.
  • Lift the battery out of the computer.
Agregar Comentario
Use a spudger to lift the back of the hinge cover on the left and right sides of the computer. Use a spudger to lift the back of the hinge cover on the left and right sides of the computer. Use a spudger to lift the back of the hinge cover on the left and right sides of the computer.
  • Use a spudger to lift the back of the hinge cover on the left and right sides of the computer.
Agregar Comentario
Guía de regalos para el día del padre
Honremos a más que nuestros padres—celebremos a todos los mentores que nos enseñaron a reparar.
Honremos a aquellos que nos enseñaron a reparar.
Lay the computer flat on a stable surface with the monitor pointing away from you.
  • Lay the computer flat on a stable surface with the monitor pointing away from you.
Agregar Comentario
Use a spudger to partially lift the hinge cover. Use a spudger to partially lift the hinge cover. Use a spudger to partially lift the hinge cover.
  • Use a spudger to partially lift the hinge cover.
Agregar Comentario
The hinge cover has a ribbon cable that is attached to the motherboard. To prevent damage, lift the hinge cover slowly. Lift the hinge cover enough to expose the ribbon cable.
  • The hinge cover has a ribbon cable that is attached to the motherboard. To prevent damage, lift the hinge cover slowly.
  • Lift the hinge cover enough to expose the ribbon cable.
Agregar Comentario
Disconnect the ribbon cable from the  motherboard and remove the hinge cover from the computer. Disconnect the ribbon cable from the  motherboard and remove the hinge cover from the computer.
  • Disconnect the ribbon cable from the motherboard and remove the hinge cover from the computer.
Agregar Comentario
Conclusión
Neil Daniels
Miembro Desde 17/01/11
1,267 Reputación
11 Guías creadas
Equipo
Cal Poly, Team 5-18, Amido Winter 2011 Miembro de Cal Poly, Team 5-18, Amido Winter 2011
CPSU-AMIDO-W11S5G18
3 Miembros
11 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 5
Últimos 30 Días: 23
Todo El Tiempo: 2,942
