Introducción
The shutter button allows for the taking of pictures. This guide will explain how to get to and remove the shutter button and components that are associated with it.
Remove the screws from the bottom of the camera using the tri-wing screwdriver.
  • Remove the screws from the bottom of the camera using the tri-wing screwdriver.
    • Three 5.4 mm tri-head screws.
Agregar Comentario
Remove screws from charger side of camera using the Phillips 00 screwdriver.
  • Remove screws from charger side of camera using the Phillips 00 screwdriver.
    • Two 3.3 mm Phillips #00 screws.
Agregar Comentario
Remove screws from wrist-strap side of camera using the Phillips 00 screwdriver.
  • Remove screws from wrist-strap side of camera using the Phillips 00 screwdriver.
Agregar Comentario
Separate the front and back casing using the spudger. Gently pull apart the two casings. Pull the back casing away from the camera.
  • Separate the front and back casing using the spudger.
  • Gently pull apart the two casings.
  • Pull the back casing away from the camera.
Agregar Comentario
Remove screws from the casing covering the LCD using the Phillips 00 screwdriver.
  • Remove screws from the casing covering the LCD using the Phillips 00 screwdriver.
    • Remove the fifteen 2.9 mm Phillips #00 screws.
Agregar Comentario
Slide casing out using the spudger.
  • Slide casing out using the spudger.
Agregar Comentario
Gently remove the LCD display data cable by gripping the end that is connected to the motherboard and pulling out. Gently remove the LCD display data cable by gripping the end that is connected to the motherboard and pulling out.
  • Gently remove the LCD display data cable by gripping the end that is connected to the motherboard and pulling out.
Agregar Comentario
Pull on the shutter button display data cable on the end connected to the motherboard until it slides out. Pull on the shutter button display data cable on the end connected to the motherboard until it slides out.
  • Pull on the shutter button display data cable on the end connected to the motherboard until it slides out.
Agregar Comentario
While slightly rotating the shutter button and data cable counter-clockwise, pull out until whole component comes out. When inserting the new shutter button and data cable component, be sure it is placed properly into the camera or it will not function correctly.
  • While slightly rotating the shutter button and data cable counter-clockwise, pull out until whole component comes out.
    • When inserting the new shutter button and data cable component, be sure it is placed properly into the camera or it will not function correctly.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Sarah Looper
Miembro Desde 11/03/13
76 Reputación
7 Guías creadas
Equipo
Clemson, Team 13-4, Benson Spring 2013 Miembro de Clemson, Team 13-4, Benson Spring 2013
CLEM-BENSON-S13S13G4
2 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 4
Últimos 30 Días: 6
Todo El Tiempo: 723
