Introducción
The lens is the part of the camera that allows for picture taking, zoom, and many of the essential features of the camera. The lens or the gears in the lens can become damaged, therefore causing the camera to function improperly. This guide explains how to install a new lens.
Remove the screws from the bottom of the camera using the tri-wing screwdriver.
  • Remove the screws from the bottom of the camera using the tri-wing screwdriver.
    • Three 5.4 mm tri-head screws.
Agregar Comentario
Remove screws from charger side of camera using the Phillips 00 screwdriver.
  • Remove screws from charger side of camera using the Phillips 00 screwdriver.
    • Two 3.3 mm Phillips #00 screws.
Agregar Comentario
Remove screws from wrist-strap side of camera using the Phillips 00 screwdriver.
  • Remove screws from wrist-strap side of camera using the Phillips 00 screwdriver.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Separate the front and back casing using the spudger. Gently pull apart the two casings. Pull the back casing away from the camera.
  • Separate the front and back casing using the spudger.
  • Gently pull apart the two casings.
  • Pull the back casing away from the camera.
Agregar Comentario
Remove screws from motherboard using the Phillips 00 screwdriver.
  • Remove screws from motherboard using the Phillips 00 screwdriver.
    • Two 2.5 mm widehead Phillips screws
    • One 3.3 mm #00 Phillips screws
    • Three 2.5 mm #00 Phillips screws (black screws)
Agregar Comentario
Rotate the front cover clockwise onto its side and remove the single screw on the side using a Phillips 00 screwdriver.
  • Rotate the front cover clockwise onto its side and remove the single screw on the side using a Phillips 00 screwdriver.
    • Remove 3.3 mm #00 Phillips screw from the side of the front screen.
Agregar Comentario
Firmly grasp both the motherboard and front cover. Slowly pull the front cover away from the motherboard. Do not be alarmed if it takes substantial pressure to separate the two.
  • Firmly grasp both the motherboard and front cover. Slowly pull the front cover away from the motherboard.
    • Do not be alarmed if it takes substantial pressure to separate the two.
Agregar Comentario
Firmly grasp the lens and pull completely from housing. Firmly grasp the lens and pull completely from housing. Firmly grasp the lens and pull completely from housing.
  • Firmly grasp the lens and pull completely from housing.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Sarah Looper
Miembro Desde 11/03/13
76 Reputación
7 Guías creadas
Equipo
Clemson, Team 13-4, Benson Spring 2013 Miembro de Clemson, Team 13-4, Benson Spring 2013
CLEM-BENSON-S13S13G4
2 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 11
Todo El Tiempo: 1,116
