Introducción
The lens filter set is responsible for the correct color filtering of the pictures taken. To get to the filter set, remove the electrowind tape and remove the screws holding the lens filter set in place.
Remove the screws from the bottom of the camera using the tri-wing screwdriver.
  • Remove the screws from the bottom of the camera using the tri-wing screwdriver.
    • Three 5.4 mm tri-head screws.
Agregar Comentario
Remove screws from charger side of camera using the Phillips 00 screwdriver.
  • Remove screws from charger side of camera using the Phillips 00 screwdriver.
    • Two 3.3 mm Phillips #00 screws.
Agregar Comentario
Remove screws from wrist-strap side of camera using the Phillips 00 screwdriver.
  • Remove screws from wrist-strap side of camera using the Phillips 00 screwdriver.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Separate the front and back casing using the spudger. Gently pull apart the two casings. Pull the back casing away from the camera.
  • Separate the front and back casing using the spudger.
  • Gently pull apart the two casings.
  • Pull the back casing away from the camera.
Agregar Comentario
Remove electrowind strip from font cover. The front cover does not have to be separated from the device for this step or the next ones.
  • Remove electrowind strip from font cover.
    • The front cover does not have to be separated from the device for this step or the next ones.
Agregar Comentario
Remove lens data cable by gently pulling it out.
  • Remove lens data cable by gently pulling it out.
Agregar Comentario
Remove lens filter.
  • Remove lens filter.
    • There are multiple square pieces, so be sure to remove them all.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Sarah Looper
Miembro Desde 11/03/13
76 Reputación
7 Guías creadas
Equipo
Clemson, Team 13-4, Benson Spring 2013 Miembro de Clemson, Team 13-4, Benson Spring 2013
CLEM-BENSON-S13S13G4
2 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 461
