Saltar al contenido principal
Fujifilm Finepix F10 6.3 MP LCD Replacement
Qué necesitas
  1. Fujifilm Finepix F10 6.3 MP LCD Replacement, Back Cover: paso 1, imagen 1 de 1
    • Remove the screws from the bottom of the camera using the tri-wing screwdriver.
    • Three 5.4 mm tri-head screws.
  2. Fujifilm Finepix F10 6.3 MP LCD Replacement: paso 2, imagen 1 de 1
    • Remove screws from charger side of camera using the Phillips 00 screwdriver.
    • Two 3.3 mm Phillips #00 screws.
  3. Fujifilm Finepix F10 6.3 MP LCD Replacement: paso 3, imagen 1 de 1
    • Remove screws from wrist-strap side of camera using the Phillips 00 screwdriver.
  4. Fujifilm Finepix F10 6.3 MP LCD Replacement: paso 4, imagen 1 de 3 Fujifilm Finepix F10 6.3 MP LCD Replacement: paso 4, imagen 2 de 3 Fujifilm Finepix F10 6.3 MP LCD Replacement: paso 4, imagen 3 de 3
    • Separate the front and back casing using the spudger.
    • Gently pull apart the two casings.
    • Pull the back casing away from the camera.
  5. Fujifilm Finepix F10 6.3 MP LCD Replacement, LCD: paso 5, imagen 1 de 1
    • Remove screws from the casing covering the LCD using the Phillips 00 screwdriver.
    • Remove the fifteen 2.9 mm Phillips #00 screws.
  6. Fujifilm Finepix F10 6.3 MP LCD Replacement: paso 6, imagen 1 de 1
    • Slide casing out using the spudger.
  7. Fujifilm Finepix F10 6.3 MP LCD Replacement: paso 7, imagen 1 de 2 Fujifilm Finepix F10 6.3 MP LCD Replacement: paso 7, imagen 2 de 2
    • Gently remove the LCD display data cable by gripping the end that is connected to the motherboard and pulling out.
Conclusión
Una persona más ha completado esta guía.
Sarah Looper
Miembro Desde 03/11/13
100 Reputación
7 Guías creadas
Equipo
Clemson, Team 13-4, Benson Spring 2013 Miembro de Clemson, Team 13-4, Benson Spring 2013
CLEM-BENSON-S13S13G4
2 Miembros
16 Guías creadas
3 comentarios
Great Guide! Worked great to replace my screen!
Daniel - Contestar
Awesome guide! BEST WORK I'VE EVER SEEN ON A REPAIR GUIDE
Johnston Thayer - Contestar
Shutter button replacement was great too!
Daniel -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 963
