Introducción
This guide will instruct camera owners how to take off the outer casing and how to access the red, rubber power button. Once you access the button, you can remove it and replace the button with a new one.
Qué necesitas
Locate and remove two 6.4mm screws on the bottom of the camera with a Phillips #00 screwdriver.
Look on the inside of the black back casing.
Locate the red, rubber power button.
To reassemble your device, follow the instructions from the "Disassembling Fujifilm Endeavor 100ix Outer Casing" guide in reverse order.
