Introducción
Use this guide to replace the battery door.
Partes
No se requieren partes.
Locate and remove two 6.4mm screws on the bottom of the camera with a Phillips #00 screwdriver.
  • Locate and remove two 6.4mm screws on the bottom of the camera with a Phillips #00 screwdriver.
Agregar Comentario
Locate the battery door.
  • Locate the battery door.
Agregar Comentario
Locate the latch on the battery door.
  • Locate the latch on the battery door.
  • Use your finger pry to it open where it says "BATT."
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove the battery from the camera by pulling the battery door outward.
  • Remove the battery from the camera by pulling the battery door outward.
Agregar Comentario
Locate and remove three black 3.80mm screws on the back of the black casing with the Phillips #00 screwdriver.
  • Locate and remove three black 3.80mm screws on the back of the black casing with the Phillips #00 screwdriver.
Agregar Comentario
Squeeze the camera placing a thumb on the tab marked CE.
  • Squeeze the camera placing a thumb on the tab marked CE.
  • Pull the back half of the camera firmly away from the camera body.
Agregar Comentario
Locate and remove the 3.80mm screw that holds the plastic strip to the camera body with a Phillips #00 screwdriver. The plastic strip will now come off the camera body.
  • Locate and remove the 3.80mm screw that holds the plastic strip to the camera body with a Phillips #00 screwdriver.
  • The plastic strip will now come off the camera body.
Agregar Comentario
Conclusión
Eric Nicolai
Miembro Desde 10/01/11
679 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 13-5, Forte Winter 2011 Miembro de Cal Poly, Team 13-5, Forte Winter 2011
CPSU-FORTE-W11S13G5
5 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 2
Todo El Tiempo: 1,638
