Introducción
How to remove and replace the logic board.
Partes
No se requieren partes.
Remove the batteries from the camera to prevent danger of electric shock.
  • Remove the batteries from the camera to prevent danger of electric shock.
Agregar Comentario
Locate all five screws on the camera. Then proceed to remove all the screws. Locate all five screws on the camera. Then proceed to remove all the screws. Locate all five screws on the camera. Then proceed to remove all the screws.
  • Locate all five screws on the camera. Then proceed to remove all the screws.
Agregar Comentario
Beware, if your screwdriver does not fit properly, you may damage the screws' heads.
  • Beware, if your screwdriver does not fit properly, you may damage the screws' heads.
  • If your screwdriver does not fit, or you do not have the proper one, you can use a hot glue gun to fix the screwdriver to the head of the screw. Wait for it to harden slightly, and then try to remove the screws.
Agregar Comentario
Remove outer case.  Pull the back away from the main body of the camera. Remove outer case.  Pull the back away from the main body of the camera.
  • Remove outer case. Pull the back away from the main body of the camera.
Agregar Comentario
Locate the LCD screen and anchoring screw.
  • Locate the LCD screen and anchoring screw.
  • Remove screw.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Carefully pull the LCD screen away from the board it is connected to.
  • Carefully pull the LCD screen away from the board it is connected to.
Agregar Comentario
Push both blue switches away from the holding device to unleach lcd ribbon.
  • Push both blue switches away from the holding device to unleach lcd ribbon.
  • Be careful when removing ribbon. If you damage it, you will need to replace it as well.
Agregar Comentario
Carefully detach the ribbon from where it was connected by the blue pins.
  • Carefully detach the ribbon from where it was connected by the blue pins.
Agregar Comentario
Now that everything has been disconnected from the board, remove LCD screen.
  • Now that everything has been disconnected from the board, remove LCD screen.
Agregar Comentario
Remove the two screws holding the circuit board down.
  • Remove the two screws holding the circuit board down.
Agregar Comentario
Remove black sticky tape from circuit board and camera case. Remove black sticky tape from circuit board and camera case.
  • Remove black sticky tape from circuit board and camera case.
Agregar Comentario
Gently pull the circuit board away from the front side of the camera. Be careful when removing assembly as to not break any solder leads or damage lens assembly.
  • Gently pull the circuit board away from the front side of the camera.
  • Be careful when removing assembly as to not break any solder leads or damage lens assembly.
Agregar Comentario
Remove the logic board by pulling straight away from assembly. Remove the logic board by pulling straight away from assembly.
  • Remove the logic board by pulling straight away from assembly.
Agregar Comentario
Conclusión
Cody
Miembro Desde 18/04/10
47 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 7-11, Maness Spring 2010 Miembro de Cal Poly, Team 7-11, Maness Spring 2010
CPSU-MANESS-S10S7G11
3 Miembros
4 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 3,488
