Saltar al contenido principal
Flip Video Directional button replacement or cleaning
Qué necesitas
  1. Flip Video Directional button replacement or cleaning, Outer Shell: paso 1, imagen 1 de 2 Flip Video Directional button replacement or cleaning, Outer Shell: paso 1, imagen 2 de 2
    • Turn off the device and take the batteries out.
    • Remove metal sticker under the LCD screen with a spudger.
    • This may require a large force to pry off the glued sticker.
  2. Flip Video Directional button replacement or cleaning: paso 2, imagen 1 de 1
    • Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
  3. Flip Video Directional button replacement or cleaning: paso 3, imagen 1 de 2 Flip Video Directional button replacement or cleaning: paso 3, imagen 2 de 2
    • Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
  4. Flip Video Directional button replacement or cleaning: paso 4, imagen 1 de 1
    • Open battery door. This can be done by gently depressing and sliding the battery down downward.
  5. Flip Video Directional button replacement or cleaning: paso 5, imagen 1 de 1
    • Use the spudger to separate outer shells.
    • The spudger must be inserted between the shell halves to pry the edges apart.
    • Slowly work around the outside to separate the halves.
  6. Flip Video Directional button replacement or cleaning, Flip Video Directional button replacement or cleaning: paso 6, imagen 1 de 1
    • Remove the silicone directional pad insert from the front outer shell.
    • Clean the buttons with soapy water before reassembling the device.
    • Make sure it is completely dry before placing back into the device.
Conclusión
Una persona más ha completado esta guía.
Elizabeth
Miembro Desde 04/15/10
100 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 26-21, Regan Spring 2010 Miembro de Cal Poly, Team 26-21, Regan Spring 2010
CPSU-REGAN-S10S26G21
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 1,941
