Saltar al contenido principal
Fitbit Surge Battery Replacement
Qué necesitas
  1. Fitbit Surge Battery Replacement, Battery: paso 1, imagen 1 de 2 Fitbit Surge Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Unscrew all four black 3 mm Phillips screws on the underside of the watch using a T5 screwdriver.
  2. Fitbit Surge Battery Replacement: paso 2, imagen 1 de 3 Fitbit Surge Battery Replacement: paso 2, imagen 2 de 3 Fitbit Surge Battery Replacement: paso 2, imagen 3 de 3
    • Use an X-Acto knife to cut the band above, on either side, and in between the 2 screws.
    • Note: Part of the band is hard plastic.
    • Caution: The band cannot be reattached once it is cut.
  3. Fitbit Surge Battery Replacement: paso 3, imagen 1 de 2 Fitbit Surge Battery Replacement: paso 3, imagen 2 de 2
    • Scrape away the glue beneath the hard shell portion of the band to reveal the GPS.
  4. Fitbit Surge Battery Replacement: paso 4, imagen 1 de 2 Fitbit Surge Battery Replacement: paso 4, imagen 2 de 2
    • Use a PH000 screw head to undo the newly revealed silver 4 mm Phillips screws that were hidden beneath the glue.
  5. Fitbit Surge Battery Replacement: paso 5, imagen 1 de 2 Fitbit Surge Battery Replacement: paso 5, imagen 2 de 2
    • Using a metal spudger, push down on the plastic gray square clamps on the underside of the device to dislodge the whole silver backing.
    • Note: the buttons will also come off.
  6. Fitbit Surge Battery Replacement: paso 6, imagen 1 de 1
    • Use a pick or small flathead to remove the 4 metal clamps holding device together.
    • Use a thin tool to pry the the device apart by lodging it between the clock face and back side of the device.
    • Note: a spudger may not be thin enough to fit in the seam of the device. We used the 6 inch metal ruler from the Pro Tech Toolkit.
    • Go slowly and carefully disconnect two cables before fully opening.
  7. Fitbit Surge Battery Replacement: paso 7, imagen 1 de 1
    • Gently remove the battery.
Conclusión
To reassemble your device, follow these instructions in reverse order. Keep in mind that the band will need to be cut for this repair and it cannot be reattached.
11 personas más completaron esta guía.
Angela Pitts
Miembro Desde 10/11/16
1,187 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 1-3, Leahy Fall 2016 Miembro de USF Tampa, Team 1-3, Leahy Fall 2016
USFT-LEAHY-F16S1G3
3 Miembros
4 Guías creadas
10 comentarios
I'm about to embark on replacing the battery for my fitbit surge. After having it for over 2 years it requires a charge about twice a day which get annoying.
Does removing/replacing the battery require the moderate soldering skill?
L “Rico” Hirano - Contestar
Looks like it must.
Chaspsmith - Contestar
The last photo I think shows the tool prying the force feedback motor, the battery is the white plastic covered slim brick on the top right.
csaba.toth.us - Contestar
You do not need to cut bands off
Tim master - Contestar
The replacement battery for the Fitbit Surge can be found here:
It also includes all of the tools (except soldering iron) needed for the repair.
michaelf33707 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 24
Ultimos 30 días: 58
Todo El Tiempo: 19,494
