Saltar al contenido principal
Fitbit Blaze Battery Replacement
Qué necesitas
  1. Fitbit Blaze Battery Replacement, Wristband: paso 1, imagen 1 de 2 Fitbit Blaze Battery Replacement, Wristband: paso 1, imagen 2 de 2
    • Locate the front LCD screen on your device.
    • Fitbit logo should appear in the bottom center of the screen.
  2. Fitbit Blaze Battery Replacement: paso 2, imagen 1 de 1
    • Push the screen out through the back of the metal ring enclosure.
    • Use a small amount of force on screen to prevent damage. Use other hand to catch screen.
  3. Fitbit Blaze Battery Replacement: paso 3, imagen 1 de 3 Fitbit Blaze Battery Replacement: paso 3, imagen 2 de 3 Fitbit Blaze Battery Replacement: paso 3, imagen 3 de 3
    • Locate the metal pin behind the wristband located on the edge of metal ring.
    • Insert the pointed end of the metal spudger into the pin hold and push it into the blue rectangle enclosure.
    • Use a small amount of force to avoid damaging the pins.
    • Remove wristband.
  4. Fitbit Blaze Battery Replacement, Battery: paso 4, imagen 1 de 3 Fitbit Blaze Battery Replacement, Battery: paso 4, imagen 2 de 3 Fitbit Blaze Battery Replacement, Battery: paso 4, imagen 3 de 3
    • Place device screen face down and locate the four screws attaching the back cover.
    • Use a T3 torx head or T3 torx screwdriver to remove the four screws.
  5. Fitbit Blaze Battery Replacement: paso 5, imagen 1 de 3 Fitbit Blaze Battery Replacement: paso 5, imagen 2 de 3 Fitbit Blaze Battery Replacement: paso 5, imagen 3 de 3
    • Grab the back, lift and open like a book to expose the motherboard. Locate the ribbon connector on the left.
    • Use a plastic spudger tool on the ribbon connected from the heart rate monitor to the motherboard.
    • Insert and lift the plastic opening tool to release the ribbon.
    • Only a small force when lifting the plastic connector is needed to avoid damage.
  6. Fitbit Blaze Battery Replacement: paso 6, imagen 1 de 3 Fitbit Blaze Battery Replacement: paso 6, imagen 2 de 3 Fitbit Blaze Battery Replacement: paso 6, imagen 3 de 3
    • Separate the back and set aside, locate the three screws attaching the motherboard.
    • Use a PH000 head or a PH000 screwdriver to remove the three screws.
  7. Fitbit Blaze Battery Replacement: paso 7, imagen 1 de 3 Fitbit Blaze Battery Replacement: paso 7, imagen 2 de 3 Fitbit Blaze Battery Replacement: paso 7, imagen 3 de 3
    • Use a plastic spudger tool on the ribbons connected to the motherboard.
    • Insert the tool under the ribbon and lift to release the connection.
  8. Fitbit Blaze Battery Replacement: paso 8, imagen 1 de 3 Fitbit Blaze Battery Replacement: paso 8, imagen 2 de 3 Fitbit Blaze Battery Replacement: paso 8, imagen 3 de 3
    • Lift and push the motherboard to the side to uncover the 167mAh battery.
    • Use a plastic spudger tool to pry out the battery from its adhesive plastic underneath.
    • Lift up and pull downward to remove battery. Switch to the top portion of the battery and push downward to pry out battery.
  9. Fitbit Blaze Battery Replacement: paso 9, imagen 1 de 3 Fitbit Blaze Battery Replacement: paso 9, imagen 2 de 3 Fitbit Blaze Battery Replacement: paso 9, imagen 3 de 3
    • Flip the motherboard backwards and locate the metal pins from the battery soldered to the board.
    • Desolder the connection to remove the battery, desolder the battery connector itself if desired as well.
    • Follow this guide on how to solder and desolder connectors Soldering Guide
    • Excessive heat will damage the components, so do not apply the soldering iron to the component for long amounts of time.
Conclusión
62 personas más completaron esta guía.
Adrian Borrego
Miembro Desde 02/20/17
2,242 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S3-G3, Sullivan Spring 2017 Miembro de USF Tampa, Team S3-G3, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G3
4 Miembros
15 Guías creadas
55 comentarios
Where can I buy this battery?
Please contact fred@doble.com.br
Frederico Araujo - Contestar
no answer for:
Pierre Therien - Contestar
Looking for this battery as well; mine lasted exactly 1 year. 7 days now down to hours, the surge did the same thing, maybe my last Fitbit watch ever! Disappointed to say the least.
Darrell Way - Contestar
I found a battery, 3.7 volt at 165mAh in the same style, should be close enough but I do not have the size of the factory battery, if anyone has taken theirs apart, can you post up the measurements in mm? thanks
I can't find the battery anywhere either. Would love some advice. Tried Amazon, AliExpress, eBay and Google in general.
Chris Wilson - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 40
Ultimos 30 días: 180
Todo El Tiempo: 131,181
