Be sure to unplug the device before proceeding.
  • Be sure to unplug the device before proceeding.
  • Use a Phillips #0 screwdriver to remove the four 21.7mm screws holding the back panel to the frame.
Agregar Comentario
Once the screws are out, use a plastic opening tool or spudger to pry the top of the back panel open. There may be some resistance, but it will eventually pry loose.
  • Once the screws are out, use a plastic opening tool or spudger to pry the top of the back panel open. There may be some resistance, but it will eventually pry loose.
Agregar Comentario
Once the top is separated, use your hand to remove the back panel from the unit.
  • Once the top is separated, use your hand to remove the back panel from the unit.
Agregar Comentario
There will be two black wires connecting the top mounting bracket to the reverb box at the bottom of the unit. Label the wires to prevent crossing upon re-installation, then unplug the wires from the reverb box. There will be two black wires connecting the top mounting bracket to the reverb box at the bottom of the unit. Label the wires to prevent crossing upon re-installation, then unplug the wires from the reverb box.
  • There will be two black wires connecting the top mounting bracket to the reverb box at the bottom of the unit. Label the wires to prevent crossing upon re-installation, then unplug the wires from the reverb box.
Agregar Comentario
Label and unplug the two red wires connecting the mounting bracket to the speaker by pulling them off the nodes.
  • Label and unplug the two red wires connecting the mounting bracket to the speaker by pulling them off the nodes.
Agregar Comentario
Use a Phillips #1 screwdriver to unscrew the four 36.4 mm screws holding the mounting bracket to the top of the amp. Use a Phillips #1 screwdriver to unscrew the four 36.4 mm screws holding the mounting bracket to the top of the amp. Use a Phillips #1 screwdriver to unscrew the four 36.4 mm screws holding the mounting bracket to the top of the amp.
  • Use a Phillips #1 screwdriver to unscrew the four 36.4 mm screws holding the mounting bracket to the top of the amp.
Agregar Comentario
Pull the mounting bracket free from the frame. It may be wedged in very snug, in which case, use a plastic opening tool/spudger to pry it loose from the front. Pull the mounting bracket free from the frame. It may be wedged in very snug, in which case, use a plastic opening tool/spudger to pry it loose from the front. Pull the mounting bracket free from the frame. It may be wedged in very snug, in which case, use a plastic opening tool/spudger to pry it loose from the front.
  • Pull the mounting bracket free from the frame. It may be wedged in very snug, in which case, use a plastic opening tool/spudger to pry it loose from the front.
Agregar Comentario
Mark, make note of, or remember the arrangement of the wires. Remove the four female disconnected terminals from the switch terminals.
  • Mark, make note of, or remember the arrangement of the wires.
  • Remove the four female disconnected terminals from the switch terminals.
Agregar Comentario
Using the flat end of a spudger, push in one of the wedged locking clips. Partially tilt the switch box so that clip is held down. Repeat for the other side of the switch
  • Using the flat end of a spudger, push in one of the wedged locking clips.
  • Partially tilt the switch box so that clip is held down.
  • Repeat for the other side of the switch
Agregar Comentario
Be sure that both locking clips are pressed through the opening. This may take a few tries. Gently remove the switch.
  • Be sure that both locking clips are pressed through the opening. This may take a few tries.
  • Gently remove the switch.
Agregar Comentario
Conclusión
Once the old power switch is removed, install the new one by following the guide in reverse.
Una persona más ha completado esta guía.
Greg Sawers
Miembro Desde 27/09/12
71 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 24-30, Regan Fall 2012 Miembro de Cal Poly, Team 24-30, Regan Fall 2012
CPSU-REGAN-F12S24G30
5 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 3
Últimos 7 Días: 7
Últimos 30 Días: 44
Todo El Tiempo: 4,701
