Introducción
If your device does not have power, replace the power input jack.
Be sure to unplug the device before proceeding.
  • Be sure to unplug the device before proceeding.
  • Use a Phillips #0 screwdriver to remove the four 21.7mm screws holding the back panel to the frame.
Agregar Comentario
Once the screws are out, use a plastic opening tool or spudger to pry the top of the back panel open. There may be some resistance, but it will eventually pry loose.
  • Once the screws are out, use a plastic opening tool or spudger to pry the top of the back panel open. There may be some resistance, but it will eventually pry loose.
Agregar Comentario
Once the top is separated, use your hand to remove the back panel from the unit.
  • Once the top is separated, use your hand to remove the back panel from the unit.
Agregar Comentario
There will be two black wires connecting the top mounting bracket to the reverb box at the bottom of the unit. Label the wires to prevent crossing upon re-installation, then unplug the wires from the reverb box. There will be two black wires connecting the top mounting bracket to the reverb box at the bottom of the unit. Label the wires to prevent crossing upon re-installation, then unplug the wires from the reverb box.
  • There will be two black wires connecting the top mounting bracket to the reverb box at the bottom of the unit. Label the wires to prevent crossing upon re-installation, then unplug the wires from the reverb box.
Agregar Comentario
Label and unplug the two red wires connecting the mounting bracket to the speaker by pulling them off the nodes.
  • Label and unplug the two red wires connecting the mounting bracket to the speaker by pulling them off the nodes.
Agregar Comentario
Use a Phillips #1 screwdriver to unscrew the four 36.4 mm screws holding the mounting bracket to the top of the amp. Use a Phillips #1 screwdriver to unscrew the four 36.4 mm screws holding the mounting bracket to the top of the amp. Use a Phillips #1 screwdriver to unscrew the four 36.4 mm screws holding the mounting bracket to the top of the amp.
  • Use a Phillips #1 screwdriver to unscrew the four 36.4 mm screws holding the mounting bracket to the top of the amp.
Agregar Comentario
Pull the mounting bracket free from the frame. It may be wedged in very snug, in which case, use a plastic opening tool/spudger to pry it loose from the front. Pull the mounting bracket free from the frame. It may be wedged in very snug, in which case, use a plastic opening tool/spudger to pry it loose from the front. Pull the mounting bracket free from the frame. It may be wedged in very snug, in which case, use a plastic opening tool/spudger to pry it loose from the front.
  • Pull the mounting bracket free from the frame. It may be wedged in very snug, in which case, use a plastic opening tool/spudger to pry it loose from the front.
Agregar Comentario
Before disconnecting the wires, label, make note of, or memorize  each wire according to where it connects to the power input jack. Disconnect the wire connectors from the back of the input jack by pulling them away from the jack.
  • Before disconnecting the wires, label, make note of, or memorize each wire according to where it connects to the power input jack.
  • Disconnect the wire connectors from the back of the input jack by pulling them away from the jack.
Agregar Comentario
Use Philips #1 Screwdriver to unscrew the two 12.1 mm screws on the exterior of the power input jack. Hold the nut in place while unscrewing the 12.1 mm screws using a pair of needle nose pliers to prevent it from spinning.
  • Use Philips #1 Screwdriver to unscrew the two 12.1 mm screws on the exterior of the power input jack.
  • Hold the nut in place while unscrewing the 12.1 mm screws using a pair of needle nose pliers to prevent it from spinning.
Agregar Comentario
Pull the power input jack out of the mounting bracket.
  • Pull the power input jack out of the mounting bracket.
Agregar Comentario
Conclusión
Once the old power jack is removed, to install the replacement power jack, follow the guide in reverse.
Will
Miembro Desde 27/09/12
28 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 24-30, Regan Fall 2012 Miembro de Cal Poly, Team 24-30, Regan Fall 2012
CPSU-REGAN-F12S24G30
5 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 11
Últimos 30 Días: 54
Todo El Tiempo: 4,996
