Saltar al contenido principal
Faulty Plug Prongs Repair
Qué necesitas
  1. Faulty Plug Prongs Repair, Faulty Plug Prongs Repair: paso 1, imagen 1 de 1
    • Find the power cord.
    • Make sure that it is unplugged from the outlet. This is to make sure that no power is flowing through and you are not injured.
  2. Faulty Plug Prongs Repair: paso 2, imagen 1 de 1
    • If the prongs are bent out of shape, take the pliers and slowly apply pressure so that the prongs bend back to their regular shape.
    • It doesn't have to be perfect. It just has to fit into the outlet.
  3. Faulty Plug Prongs Repair: paso 3, imagen 1 de 1
    • Plug the power cord into the outlet and make sure that it's connected to the device.
Linea de Meta
6 personas más completaron esta guía.
Equipo
Cal Poly, Team 7-50, Forte Fall 2012 Miembro de Cal Poly, Team 7-50, Forte Fall 2012
CPSU-FORTE-F12S7G50
5 Miembros
7 Guías creadas
Un comentario
What if the casing is broken and needs to be replaced?
Bertha Torres - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 36
Ultimos 30 días: 135
Todo El Tiempo: 16,461
