Saltar al contenido principal
Epson Stylus Photo 1400 Ink cartridge replacement
Qué necesitas
  1. Epson Stylus Photo 1400 Ink cartridge replacement, ink cartridge: paso 1, imagen 1 de 2 Epson Stylus Photo 1400 Ink cartridge replacement, ink cartridge: paso 1, imagen 2 de 2
    • Open cover of the printer.
    • Open the cartridge cover by pressing down on the tab and lifting it up.
  2. Epson Stylus Photo 1400 Ink cartridge replacement: paso 2, imagen 1 de 2 Epson Stylus Photo 1400 Ink cartridge replacement: paso 2, imagen 2 de 2
    • Grab the sides of the ink cartridge and pull it out.
    • Replace ink cartridge with brand new ink cartridge.
  3. Epson Stylus Photo 1400 Ink cartridge replacement: paso 3, imagen 1 de 2 Epson Stylus Photo 1400 Ink cartridge replacement: paso 3, imagen 2 de 2
    • Close cartridge cover.
    • Close cover of the printer.
Conclusión
2 personas más completaron esta guía.
Larry Huang
Miembro Desde 10/12/11
1,004 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 17-11, Regan Fall 2011 Miembro de Cal Poly, Team 17-11, Regan Fall 2011
CPSU-REGAN-F11S17G11
4 Miembros
12 Guías creadas
5 comentarios
I cannot change the ink cartridges because when I press the Ink button they will not stop in a position where I can open the container. Nothing I've tried works -- can you help please? URGENT!!!
David Hardy - Contestar
I actually found this quite easy because of your guide. There was no issue at all with replacing the ink cartridge in my printer and now I can print again! Is there anything else I need to worry about after I put the cartridge in? http://tonertown.com.au
chrishowell562 - Contestar
You missed the part where you tell people how to get the cartridge to a position where you can open it. Mine is block because it is over to the side too far.
Paul M - Contestar
Poor instructions on how to get ink cartridge holder in right position.
rpttrsn - Contestar
Instruction intimates the ink carriage will be in position when parked. Not so…with it parked in the extreme right, you cannot get the ink cover open. jdw
joe waldroff - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 17
Todo El Tiempo: 10,072
