Introducción
If the speaker on your tablet is blown or no longer outputting sound then you may need to replace it, this guide will teach you exactly how to replace your tablets speaker.
Qué necesitas
There are two screws on the side with the micro USB power port. Remove the two 2mm x 0.5mm screws with a Phillips #0 Screwdriver head.
Casi Terminas!
To reassemble your device, follow these instructions in reverse order, note you will need to solder for this replacement.
Conclusión
