Saltar al contenido principal
Easyshare C813 Speaker Replacement
Qué necesitas
  1. Easyshare C813 Speaker Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off camera by firmly pressing the power button that is located on the top of the camera near the selector dial.
  2. Easyshare C813 Speaker Replacement: paso 2, imagen 1 de 3 Easyshare C813 Speaker Replacement: paso 2, imagen 2 de 3 Easyshare C813 Speaker Replacement: paso 2, imagen 3 de 3
    • Press thumb firmly on battery door and slide it in the direction of the arrow.
    • Lift thumb allowing the door to swing open.
  3. Easyshare C813 Speaker Replacement, Back Cover: paso 3, imagen 1 de 1
    Herramienta utilizada en este paso:
    Anti-Static Wrist Strap
    $7.95
    Comprar
  4. Easyshare C813 Speaker Replacement: paso 4, imagen 1 de 1
    • Turn the camera off by firmly pressing the power button located on top of the camera.
  5. Easyshare C813 Speaker Replacement: paso 5, imagen 1 de 3 Easyshare C813 Speaker Replacement: paso 5, imagen 2 de 3 Easyshare C813 Speaker Replacement: paso 5, imagen 3 de 3
    • Locate the 7 screws holding the back cover on.
    • Three screws are located on the bottom of the camera.
    • Two screws are located on the side shown in the photograph.
    • Two final screws are located on the opposite side shown in the photograph.
  6. Easyshare C813 Speaker Replacement: paso 6, imagen 1 de 3 Easyshare C813 Speaker Replacement: paso 6, imagen 2 de 3 Easyshare C813 Speaker Replacement: paso 6, imagen 3 de 3
    Phillips #00 Screwdriver
    $5.49
    Comprar
    • Remove all 7 screws:
    • Hold the camera firmly with one hand so that you can still see a screw.
    • Place the Philips 00(Found here)screwdriver into the screw.
    • Turn the screwdriver to the left until it is free.
    • Repeat for the remaining screws.
  7. Easyshare C813 Speaker Replacement: paso 7, imagen 1 de 3 Easyshare C813 Speaker Replacement: paso 7, imagen 2 de 3 Easyshare C813 Speaker Replacement: paso 7, imagen 3 de 3
    • Use plastic opening tools to slightly open the side of the case.
    • Insert a plastic opening tool and apply pressure to the internal three tabs at the top.
    • The first two are near the words "3X Optical Zoom".
    • The third is near the shutter button.
  8. Easyshare C813 Speaker Replacement: paso 8, imagen 1 de 3 Easyshare C813 Speaker Replacement: paso 8, imagen 2 de 3 Easyshare C813 Speaker Replacement: paso 8, imagen 3 de 3
    • Gently pull apart the back cover from the rest of the camera.
    • Make sure there are no more screws or tabs keeping the cover on.
    • Use the plastic opening tool to separate any sides still closely connected.
  9. Easyshare C813 Speaker Replacement, Front Cover: paso 9, imagen 1 de 2 Easyshare C813 Speaker Replacement, Front Cover: paso 9, imagen 2 de 2
    • Open the battery door.
  10. Easyshare C813 Speaker Replacement: paso 10, imagen 1 de 3 Easyshare C813 Speaker Replacement: paso 10, imagen 2 de 3 Easyshare C813 Speaker Replacement: paso 10, imagen 3 de 3
    • Use the plastic opening tool to lift the casing around the shutter button.
    • Gently remove the front cover from the device.
  11. Easyshare C813 Speaker Replacement: paso 11, imagen 1 de 1
    • Do not touch the terminals shown in the photo. These link to the capacitor which could shock you if not discharged.
    • To discharge the capacitor follow this guide.
  12. Easyshare C813 Speaker Replacement, LCD: paso 12, imagen 1 de 3 Easyshare C813 Speaker Replacement, LCD: paso 12, imagen 2 de 3 Easyshare C813 Speaker Replacement, LCD: paso 12, imagen 3 de 3
    • Once the front cover is removed, the battery door maybe closed for convenience.
    • Locate the exposed portion of the LCD screen.
    • Use a wedge to free the LCD screen from the medal housing.
    • Do not pull the screen away completely, it is still attached to the logic board via the yellow cable.
  13. Easyshare C813 Speaker Replacement: paso 13, imagen 1 de 1
    • Remove the screw at the upper right corner of the metal housing.
  14. Easyshare C813 Speaker Replacement: paso 14, imagen 1 de 3 Easyshare C813 Speaker Replacement: paso 14, imagen 2 de 3 Easyshare C813 Speaker Replacement: paso 14, imagen 3 de 3
    • Locate the 2 solder joints holding down the medal housing.
    • Remove the solder.
    • Place wick on solder.
    • Place solder iron on wick
    • The wick should be sandwiched between the iron and the solder.
  15. Easyshare C813 Speaker Replacement: paso 15, imagen 1 de 3 Easyshare C813 Speaker Replacement: paso 15, imagen 2 de 3 Easyshare C813 Speaker Replacement: paso 15, imagen 3 de 3
    • Peel back the black tape from the metal housing.
    • Lift the metal housing from the left so that it hinges on its right side.
    • The metal housing is still loosely attached on its right side.
  16. Easyshare C813 Speaker Replacement: paso 16, imagen 1 de 3 Easyshare C813 Speaker Replacement: paso 16, imagen 2 de 3 Easyshare C813 Speaker Replacement: paso 16, imagen 3 de 3
    • Locate black tab holding the LCD screen connector in the port.
    • Use wedge or fingernail to lift the black tab.
    • Pull the the LCD screen connector out of the port.
  17. Easyshare C813 Speaker Replacement, Logic Board: paso 17, imagen 1 de 1
    • Remove the medal housing from the logic board by carefully peeling the yellow tape off of the metal housing.
  18. Easyshare C813 Speaker Replacement: paso 18, imagen 1 de 3 Easyshare C813 Speaker Replacement: paso 18, imagen 2 de 3 Easyshare C813 Speaker Replacement: paso 18, imagen 3 de 3
    • Locate the 2 screws on the yellow tape.
    • Remove the 2 screws.
    • Remove the yellow tape.
  19. Easyshare C813 Speaker Replacement: paso 19, imagen 1 de 2 Easyshare C813 Speaker Replacement: paso 19, imagen 2 de 2
    • Locate the 2 solder joints near the shutter button.
    • Remove the solder on both joints with the wick and soldering iron in the same manner as Step 11.
  20. Easyshare C813 Speaker Replacement: paso 20, imagen 1 de 3 Easyshare C813 Speaker Replacement: paso 20, imagen 2 de 3 Easyshare C813 Speaker Replacement: paso 20, imagen 3 de 3
    • Turn the camera over.
    • Remove the screw holding the small green board.
    • Lift the small green board.
    • The small green board is still attached to the logic board via wires.
  21. Easyshare C813 Speaker Replacement: paso 21, imagen 1 de 1
    • Desolder the remaining 20 solder joints connecting the logic board to the camera.
  22. Easyshare C813 Speaker Replacement: paso 22, imagen 1 de 2 Easyshare C813 Speaker Replacement: paso 22, imagen 2 de 2
    • Locate the black tab holding the yellow cable in place.
    • Use a plastic opening tool or fingernail to lift the black tab.
    • Pull the yellow cable from the port.
  23. Easyshare C813 Speaker Replacement: paso 23, imagen 1 de 3 Easyshare C813 Speaker Replacement: paso 23, imagen 2 de 3 Easyshare C813 Speaker Replacement: paso 23, imagen 3 de 3
    • Use a plastic opening tool to lift the board from the camera.
    • Continue to remove the board completely.
  24. Easyshare C813 Speaker Replacement, Speaker: paso 24, imagen 1 de 1
    • Carefully pull the red and black wires located on the side of the camera connected to the speaker.
Conclusión
Equipo
Cal Poly, Team 24-22, Regan Spring 2010 Miembro de Cal Poly, Team 24-22, Regan Spring 2010
CPSU-REGAN-S10S24G22
4 Miembros
20 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 13
Todo El Tiempo: 1,804
