Saltar al contenido principal
Dyson Ball Multi Floor Upright Main Filter Replacement
Qué necesitas
  1. Dyson Ball Multi Floor Upright Main Filter  Replacement, Main Filter: paso 1, imagen 1 de 3 Dyson Ball Multi Floor Upright Main Filter  Replacement, Main Filter: paso 1, imagen 2 de 3 Dyson Ball Multi Floor Upright Main Filter  Replacement, Main Filter: paso 1, imagen 3 de 3
    • For the main filter, locate the body of the vacuum by looking for the cylinder with the orange top. Use your thumb to press down on the red button towards the back of the orange piece.
    • After pressing down on the red button, the body of the vacuum will easily be removed from the vacuum stand.
  2. Dyson Ball Multi Floor Upright Main Filter  Replacement: paso 2, imagen 1 de 3 Dyson Ball Multi Floor Upright Main Filter  Replacement: paso 2, imagen 2 de 3 Dyson Ball Multi Floor Upright Main Filter  Replacement: paso 2, imagen 3 de 3
    • Once the main body of the vacuum is removed, locate the clear handle on the top of the body. There is a purple label that says "Filter".
    • Lift up the clear handle to reveal the main cylindrical filter. Pull out the purple filter piece to replace.
Conclusión
3 personas más completaron esta guía.
Nicole Abraham
Miembro Desde 01/26/17
839 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 21-2, Maness Winter 2017 Miembro de Cal Poly, Team 21-2, Maness Winter 2017
CPSU-MANESS-W17S21G2
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 13
Ultimos 30 días: 40
Todo El Tiempo: 3,597
