Saltar al contenido principal
Dyson Ball Animal Brushbar Replacement
Qué necesitas
  1. Dyson Ball Animal Brushbar Replacement, Brushbar: paso 1, imagen 1 de 2 Dyson Ball Animal Brushbar Replacement, Brushbar: paso 1, imagen 2 de 2
    • Turn off and unplug the vacuum.
  2. Dyson Ball Animal Brushbar Replacement: paso 2, imagen 1 de 2 Dyson Ball Animal Brushbar Replacement: paso 2, imagen 2 de 2
    • Recline the vacuum on its back and position the brushbar up in the air.
  3. Dyson Ball Animal Brushbar Replacement: paso 3, imagen 1 de 2 Dyson Ball Animal Brushbar Replacement: paso 3, imagen 2 de 2
    • Pull the red ring around the base of the brush head down and away from the body.
  4. Dyson Ball Animal Brushbar Replacement: paso 4, imagen 1 de 1
    • Pull the brushbar out from the vacuum.
  5. Dyson Ball Animal Brushbar Replacement: paso 5, imagen 1 de 1
    • Pull up the red tabs on the top of the brushbar.
  6. Dyson Ball Animal Brushbar Replacement: paso 6, imagen 1 de 1
    • Remove the front panel of the brushbar.
  7. Dyson Ball Animal Brushbar Replacement: paso 7, imagen 1 de 3 Dyson Ball Animal Brushbar Replacement: paso 7, imagen 2 de 3 Dyson Ball Animal Brushbar Replacement: paso 7, imagen 3 de 3
    • Remove the four screws with a Torx T10 Screwdriver.
  8. Dyson Ball Animal Brushbar Replacement: paso 8, imagen 1 de 2 Dyson Ball Animal Brushbar Replacement: paso 8, imagen 2 de 2
    • Lift the brushbar away from the housing while pulling it out to the side.
    • This may take some force and wiggling.
Conclusión
21 personas más completaron esta guía.
Mairead Nye
Miembro Desde 05/07/17
426 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S15-G5, Banghart Spring 2017 Miembro de Cal Poly, Team S15-G5, Banghart Spring 2017
CPSU-BANGHART-S17S15G5
4 Miembros
16 Guías creadas
15 comentarios
I'm like to know if this works for the Dyson ball animal2 as well
Jean Riehle - Contestar
It does work
ade 23 -
We used this guide to clean the brushbar assembly of the DC41 animal too. Thank you SO MUCH for writing it!!! We’d never have tried pulling the bar off sideways.
Anthony Clark - Contestar
Thanks to MaireadNye for the easy to follow guide. I used this to remove and clean the brush bar and its housing on a Dyson Animal 2 upright vacuum. The four screws securing the brush bar were not T10 Torx, but rather Phillips head, so no big deal. What took the longest amount of time was searching for my Torx tools before I began, which is unlike me. I usually grab tools as I go, but since only one was required, I decided to (unnecessarily) have it ready to go. I used vinegar first to get out a soy sauce type smell, but dish soap was what worked. Thanks again!
(And thanks to Dyson for making stuff like this user-friendly!)
renee marie - Contestar
what is the part and part number of the wheel in between the brush bar?
Jerry Taylor - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 46
Ultimos 7 días: 198
Ultimos 30 días: 675
Todo El Tiempo: 83,123
