Saltar al contenido principal
Disassembling the Nokia 6300
Qué necesitas
  1. Disassembling the Nokia 6300, Rear Cover: paso 1, imagen 1 de 1
    • Take off the back cover by pushing it down and sliding it backwards.
  2. Disassembling the Nokia 6300: paso 2, imagen 1 de 2 Disassembling the Nokia 6300: paso 2, imagen 2 de 2
    • Take out the battery, SIM card, and MicroSD card.
    • Unscrew the two T6 Torx screws.
  3. Disassembling the Nokia 6300: paso 3, imagen 1 de 1
    • Try to seperate the front cover from the rest of the phone. The front cover is held by four plastic clips.
    • The first time you do this you may have to use some force but do it in a controlled way. If you break the plastic clips you'll need a new front cover.
  4. Disassembling the Nokia 6300: paso 4, imagen 1 de 1
    • You can take off the keypad now, this is sitting loose on top of the sensors.
    • Unscrew the four remaining T6 Torx screws.
    • The screws holding the motherboard in place are different from the two previous screws which held the rear cover in place.
  5. Disassembling the Nokia 6300: paso 5, imagen 1 de 1
    • The motherboard with it's screen are now loose, you can pop it right out.
    • If you've been using this phone for a while, there's probably some dust inside the back shell.
    • There's a lot of contacts exposed, so make sure not to damage those.
  6. Disassembling the Nokia 6300: paso 6, imagen 1 de 3 Disassembling the Nokia 6300: paso 6, imagen 2 de 3 Disassembling the Nokia 6300: paso 6, imagen 3 de 3
    • There's your phone!
Conclusión
20 personas más completaron esta guía.
LucasJV
Miembro Desde 05/18/10
735 Reputación
3 Guías creadas
Equipo
Verheij.co Miembro de Verheij.co
Business
1 Miembro
5 Guías creadas
Un comentario
in this where is bluetooth module plzz give me ans @ bhatia.abhi98@gmail.com
abhishek - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 34
Todo El Tiempo: 23,678
