Saltar al contenido principal
Disassembling the Garmin eTrex Vista-H Outer Case
Qué necesitas
  1. Disassembling the Garmin eTrex Vista-H Outer Case, Removing Battery: paso 1, imagen 1 de 1
    • Flip the device to the backside, and locate the metal tab at the center of the back cover.
  2. Disassembling the Garmin eTrex Vista-H Outer Case: paso 2, imagen 1 de 1
    • Lift the metal tab up, and rotate it counterclockwise. This will unlock the back case cover.
  3. Disassembling the Garmin eTrex Vista-H Outer Case: paso 3, imagen 1 de 2 Disassembling the Garmin eTrex Vista-H Outer Case: paso 3, imagen 2 de 2
    • Lift the battery plate off to either insert or remove 2 AA batteries.
  4. Disassembling the Garmin eTrex Vista-H Outer Case, Disassembling the Garmin eTrex Vista-H Outer Case: paso 4, imagen 1 de 2 Disassembling the Garmin eTrex Vista-H Outer Case, Disassembling the Garmin eTrex Vista-H Outer Case: paso 4, imagen 2 de 2
    • With the wedge side of a spudger (or a small, flat head screwdriver), remove the black rubber case support from the device body.
  5. Disassembling the Garmin eTrex Vista-H Outer Case: paso 5, imagen 1 de 3 Disassembling the Garmin eTrex Vista-H Outer Case: paso 5, imagen 2 de 3 Disassembling the Garmin eTrex Vista-H Outer Case: paso 5, imagen 3 de 3
    • With the pick side of a spudger (or tweezers), peel the sticky tape from the device.
  6. Disassembling the Garmin eTrex Vista-H Outer Case: paso 6, imagen 1 de 1
    • Split the front and rear panels by inserting a small pointed tool (such as a pen point or a screwdriver tip SL1.5) in the 5 plastic tabs along the sides of the device.
    • Do not remove the back panels quickly. If too much force is applied, there is a wire connection that will break.
    • CAUTION! Be careful not to force the tabs inward. This will result in broken tabs.
  7. Disassembling the Garmin eTrex Vista-H Outer Case: paso 7, imagen 1 de 2 Disassembling the Garmin eTrex Vista-H Outer Case: paso 7, imagen 2 de 2
    • With tweezers (or your fingernails), carefully disconnect the wires between the PC input and the motherboard.
Conclusión
7 personas más completaron esta guía.
Ryan Green
Miembro Desde 10/17/10
93 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 21-30, Regan Fall 2010 Miembro de Cal Poly, Team 21-30, Regan Fall 2010
CPSU-REGAN-F10S21G30
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 4,982
