Saltar al contenido principal
Disassembling iPhone 4S Back Camera
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Qué necesitas
  1. Disassembling iPhone 4S Back Camera, Disassembling iPhone 4S Battery: paso 1, imagen 1 de 1
    • Using a 5-point pentalobe screwdriver, unscrew the 2 pentalobe on the bottom of the phone near the dock connector.
  2. Disassembling iPhone 4S Back Camera: paso 2, imagen 1 de 1
    • Push the back glass towards the top of the phone.
  3. Disassembling iPhone 4S Back Camera: paso 3, imagen 1 de 1
    • Using a #000 Phillips screwdriver, unscrew the 2 very small Phillips screws.
  4. Disassembling iPhone 4S Back Camera: paso 4, imagen 1 de 2 Disassembling iPhone 4S Back Camera: paso 4, imagen 2 de 2
    • Using a plastic opener tool, pry up the battery connector shield. Be careful not to lose the smaller antenna connector shield under the top connector sheild.
    • Using a plastic opener tool, pry up the battery connector.
  5. Disassembling iPhone 4S Back Camera: paso 5, imagen 1 de 1
    • Pull upwards on the plastic tab. If it's the first time, you may have to use the plastic pry tool on the outside (right) edge of the battery to loosen battery first.
    • Then, out pops the battery.
  6. Disassembling iPhone 4S Back Camera, Disassembling iPhone 4S Back Camera: paso 6, imagen 1 de 1
    • Unscrew the 4 phillips screws holding the shield covering 6 of the 8 connectors.
    • Make sure to keep track of which screws are which, they very by tenths of a millimeter.
  7. Disassembling iPhone 4S Back Camera: paso 7, imagen 1 de 2 Disassembling iPhone 4S Back Camera: paso 7, imagen 2 de 2
    • Using a plastic opening tool, pry the back camera connector from the logic board.
    • Be careful not to lose the small square peice of plastic covering the bottom of the camera, it comes off very easily.
Conclusión
4 personas más completaron esta guía.
Chandler Skinner
Miembro Desde 10/15/11
3,710 Reputación
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 12
Todo El Tiempo: 2,688
